Original Hydro?
Posted 06 February 2016 - 06:41 PM
Posted 06 February 2016 - 08:03 PM
Posted 06 February 2016 - 08:07 PM
Not sure, my first guess would be dry...
Is the car still on hydrolastic displacers?
Posted 06 February 2016 - 08:12 PM
From the angle you have shown, they look like hydro arms to me
Are they any specific photos I could take that would help?
The car was still on hydro displacers when I took it all apart last week, and I had been driving it like that for over 5 years.
Posted 06 February 2016 - 08:16 PM
The ones in in the photo show the flat joining with a radium
Posted 06 February 2016 - 08:17 PM
So PDaykin was right, they are hydro top arms.
With hydro cars it is quite normal to fit front shock absorbers, this helps to steady up the ride. Best used together with the competition bump-stops, this combination give very good ride and handling.
Posted 06 February 2016 - 08:27 PM
I put a reply to your posting on the MKI site.
Posted 06 February 2016 - 08:31 PM
Dry top arms are quite square where the 'flat' joins near the knuckle area.
Thank you!
I think that is why there were fitted by a previous owner, and I intend to keep them :)
I was just wondering whether anyone knew about how the upper mount fixes to the inner wing, to help identify my shell???
Posted 06 February 2016 - 08:36 PM
Thanks, I will have a look now. I just find it useful asking in a few different places. Thanks again.
Posted 06 February 2016 - 08:40 PM
There were four captive nuts on the inner wing ready to bolt the bracket on to
Edited by pdaykin, 06 February 2016 - 08:40 PM.
Posted 06 February 2016 - 08:47 PM
Pretty sure that the fixings for shocks were always present on the inner wing even with hydro cars. However, the actual bracket for the shock wasn't fitted.
This is what I thought the case would be, but I only have captive nuts at the top. Seems like I will just have to weld some captive nuts at the bottom.
Thanks for all your help.
Posted 07 February 2016 - 12:10 PM
I put nuts and bolts into the two lower holes which,as you say,didn't have captive nuts.
Posted 07 February 2016 - 07:24 PM
The captive bracket for the shock absorber bracket at the top but not at the bottom is quite normal for hydrolastic cars.
Posted 07 February 2016 - 07:45 PM
Thanks for everyones replies.
When tidying up the arms ready for painting this morning I found some more useful part numbers on the castings.
Drivers Side MOWOG 21A 1480
Passenger's side MOWOG 21A 1483
These numbers are only 1 away from the part numbers listed for hydro top arms from a number of mini parts suppliers; and I think that a lot of part numbers were one different between the part number and casting number (not quite sure where I read that!)
I also took some measurements, as found elsewhere on the internet, which also points towards them being hydro top arms
Looks like they are def hydro arms
Thanks for all your help!
