Black bonnet for sure. paint it green people will think oh its not the same colour bla de blah but painting it black makes it look carbon fibrey from a distance which gives a bigger impression of speed.
Hayabusa mini
titters
, Aug 20 2006 06:19 PM
24 replies to this topic
#16
Posted 23 August 2006 - 03:47 PM
#17
Posted 23 August 2006 - 03:51 PM
That is beautiful, Look after it!
#18
Posted 23 August 2006 - 04:03 PM
love it, ta for the extra pics
#19
Posted 24 August 2006 - 12:00 AM
hey there,
Your busad mini is looking lovely but could i ask how you have fitted your miglias, i have recently bought some and i am asking around to see how people have fitted them. So how have you fitted your arches? was it a long pregress and have you have any problems with them at all?
And again you have yourself a loverly car mate max Kudos!
#20
Posted 24 August 2006 - 08:46 AM
I think most people make some small allay brackets to hold them on from what I have seen at shows. Hope this helps
#21
Posted 24 August 2006 - 09:37 AM
HI all thanks for your comments!!!
i fitted my arches with some small zink coated brackets from B&Q, If the arches you have where like mine from curley carbon i had to remove loads off the back face to get them to fit right. You will need to take your time over this to get them looking good, i think i had to cut 30 mm of the rear ones to get them on correctly. i got my mate to hold the arch over the wheel with the front face in line with the tyre at the corret height then using you finger and a marker pen put your finger against the body and clamp the pen with your thumb then follow the arch round this will leave a pen mark on the bits you neen to cut away. when you have cut those bits off with a dremal do the same again and you should see the front face getting closer to the tyre and each time you take a cut just offer the arck to the body and it should follow the shape of the body , but remember that you have to stop when you get close to the edge of your tyre because of the width of your finger! it sounds more complicated than it is but do take you time. i also put a piece of rubber trim on the edge between body and arch this can be moved about a little to hide any gaps!!
hope this helps and i will post you a close up pic when i get home later!
Chris
Chris
#22
Posted 25 August 2006 - 09:38 PM
z cars to a next step so much going on there mate beautiful project.
#23
Posted 25 August 2006 - 10:44 PM
alrite mate , what kit did you bye from z cars and how much did it cost
#24
Posted 26 August 2006 - 12:38 AM
thanks alot titters, pete with the z cars pick up aslso said i will need to fut a bit away from the arch to get it right with the body, i think i will try the little bracklet idea because thats what seems to be the most popular at the moment. titters some pics would be great but if you cant manage it then dont worry.
thanks alot for your help! Tomm
#25
Posted 28 April 2008 - 12:23 PM
hey guy, im from oz and really want to get into a minibusa. whats the first set? can i do it without a kit? can they be road legal?
