Speedo Drive Not Working
Posted 09 February 2016 - 03:25 PM
If not could I jack up the passenger side and let the oil sit the other end of the block.
thanks in advance
Stephen
Posted 09 February 2016 - 03:46 PM
This kind of fault is more likely to be the drive gear the cable connects to rather than the pinion in the gearbox.
The pinion is metal, the drive gear is plastic.
You can get to it from underneath, a ramp or lift would make it easy but you can do it on the drive - if you can get the cable off the drive gear there is a small 1/4" or 3/8" bolt which holds the C-shaped retaining plate, once both bold and C-retainer are removed you can pull the drive gear out.
It's a pain in the proverbial but it can be done.
Phil.
PS While I think about it, the cable needs to fit snuggly into the drive gear on the gearbox. The aftermarket cables can be a touch undersized in the square section which plugs into the drive gear - which would cause the drive to spin and the speedo not to work. If the square section is too small you can either try to reduce the size of the square socket in the drive gear the cable connects into, or use a small wedge or shim to make up the difference in size.
Good luck !!
Edited by phil hill, 09 February 2016 - 03:46 PM.
Posted 09 February 2016 - 03:56 PM
Posted 09 February 2016 - 04:30 PM
i take the rad out to get to it, pain that is as well but i got big hands.
Posted 09 February 2016 - 04:39 PM
Take the rad out....
Posted 09 February 2016 - 04:58 PM
Posted 09 February 2016 - 05:02 PM
No, no need to drain gearbox.
Posted 09 February 2016 - 05:15 PM
Posted 09 February 2016 - 09:28 PM
thanks for your help
