Exhaust Valves
engine
3 replies to this topic
#1 1963MKI
1963MKI
  • 163 posts
Posted 10 February 2016 - 09:34 PM
I can not remove the exhaust valves from my cylinder head. They move freely but it appears that the top of the valve stem is slightly mushroom shaped so I cant slide them out through the guides ?
#2 Carlos W
Carlos W
  • 10,115 posts
Posted 10 February 2016 - 09:38 PM
Have you removed the valve stem oil seals?
#3 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 10 February 2016 - 10:54 PM
Your best bet, is to run round the top of the valve with a wet stone or file to take the burr off the top. If you push them through the guide as they are, they could score the guide.
#4 MRA
MRA
  • 7,607 posts
Posted 18 February 2016 - 12:32 AM
As the valves are scrap file the burr off and throw them away, the reason for the damage is probably poorly set valve rocker clearances sometime in its lifetime. ....
You will quite likely also find your camshaft is scrapped, I would put a DTI (Dial Test Indicator) in each push rod in turn and check to see if all the inlet have the same lift and all the exhaust have the same lift !
Do not check inlet to exhaust as they may have different lift heights from each other.
If you find that there is no commonality in height across each push rod you may have a damaged camshaft, further checks could be checking the overall displacement of each pushrod to see if you have the same lift but at different positions, ie poorly ground camshaft, this would not be an issue, however the wear if present will be.
