Are 7Mm Silicone Ht Leads Sufficient?
9 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 11 February 2016 - 08:16 PM
Want yellow silicone leads, but decent ones only seem to come in 7mm. Is there any really difference between 7 and 8mm
#2 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 11 February 2016 - 10:06 PM
1mm?
#3 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 February 2016 - 10:10 PM
well done, you can subtract :-)
OK I'll rephrase the question in order to filter out any comedians. Is there a loss of power using a 7mm HT lead compered to an 8mm HT lead. Am I likely to notice any difference?
#4 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 11 February 2016 - 10:33 PM
No.
#5 giannoutsos
giannoutsos
  • 58 posts
Posted 12 February 2016 - 05:34 AM
Good morning,
As Gaham says 1mm difference of insulation, don't think you'll notice any difference.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 February 2016 - 12:53 PM
The diameter of the wire jacket doesn't make a bit of difference except of course that it must fit the distributor cap you are using.  Focus on the construction of the wire's core.  Check online reviews of what you plan to buy.  Keep in mind that people are more likely to complain than praise so reviews are often slanted slightly negative.
#7 mini13
mini13
  • 3,811 posts
Posted 12 February 2016 - 01:29 PM
the 8mm and thicker stuff is really aimed at cars where the leads are running near exhaust manifolds and turbo's.
#8 Dusky
Dusky
  • 5,322 posts
Posted 12 February 2016 - 05:30 PM
The 8mm stuff is aimed at the pubpoints guys to be honest
#9 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 February 2016 - 06:24 PM
7mm will do me then. Cheers
#10 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 12 February 2016 - 08:15 PM
8mm would seal moisture out a tiny little bit better though.
