brakes
9 replies to this topic
#1 day101
day101
  • 610 posts
  • Local Club: Dont have one:(
Posted 20 August 2006 - 09:47 PM
right brake light isnt coming on, checked the fuses under the bonnet all ok, any one help? please!
Luke
Edited by day101, 20 August 2006 - 09:52 PM.
#2 RacingGreen
RacingGreen
  • 2,111 posts
Posted 20 August 2006 - 09:53 PM
have you checked the bulb, all of the connections in the light? It could be a bad earth.
#3 day101
day101
  • 610 posts
Posted 21 August 2006 - 08:02 AM
got to check the bulbs yet but never had tis problem before could it be the switch has had it?
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 August 2006 - 08:09 AM
The switches are notoriously C**p....
#5 ceejam
ceejam
  • 113 posts
  • Local Club: Scottish Mini
Posted 21 August 2006 - 02:48 PM
How old is the car?
Old ones had a pressure siwthc, later cars had a switch on the pedal. Later ones are quite easy to knock the connections off.
#6 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 21 August 2006 - 03:33 PM
But a faulty switch would mean that both lights would not work.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 21 August 2006 - 04:16 PM
So one of your brake lights is not working, silly question, but have you changed the bulb ?
#8 day101
day101
  • 610 posts
Posted 21 August 2006 - 05:48 PM
Right, checked the blubs today and they work fine when the head lights are on, took the wires of the pedal switch and bypassed the switch and nothing still ;D so i dont think its the switch the blubs are ok, going to get a tester on it see if there is any current going throu or not and try and trace it back. any advice or not guys? the car is also a G reg
Edited by day101, 21 August 2006 - 05:49 PM.
#9 day101
day101
  • 610 posts
Posted 22 August 2006 - 09:13 AM
anyone?
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 August 2006 - 09:27 AM
You do realise the brake light bulb is a twin fillament bulb so the side lights is a different circuit to the brakes... so your sidelights may still work but the fillament for the brakes could be blown...
Easy way to check, one look at the bulb, and two, swap the ns and os bulbs, if the problem mves then the problems with the bulb, if it stays where it is, then the problems with the wiring.
