Radius Arm Long Shot...
9 replies to this topic
#1 cheesebadger
cheesebadger
    Formally known as rich080487.
  • 226 posts
  • Local Club: MKMOC
Posted 14 February 2016 - 10:01 PM
Hi,
I am starting to refurb my hydro radius arms as part of a larger restoration.
I have access to presses and lathes at work, so would like to change the bearings and bushes myself.
I have done plenty of research on this, and it seems like I need either the original bmc tool (18G588?) or a 13/16" reamer and a lathe.
I think that buying the official reamer is out of the question, but does anybody close to me have one that I could come and use in exchange for beer tokens? I live in Welwyn Garden City, work in Milton Keynes and I am travelling back to Bristol soon to catch up with some uni mates; so I have a large ish travelling area...
Any help appreciated, particularly any advice from anyone who has gone down the reamer plus lathe route.
Thanks,
Rich
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 14 February 2016 - 11:21 PM
I have the tools and you can certainly borrow but I'm in Southampton
#3 Ethel
  • 26,107 posts
Posted 14 February 2016 - 11:45 PM
You can pick up 13/16ths reamers, I got one from Tracy tools (online) that's a good length. If you have access to a lathe you can knock up a guide for it that sits in place of the roller bearing in the other end.
#4 cheesebadger
cheesebadger
  • 226 posts
  • Local Club: MKMOC
Posted 15 February 2016 - 08:14 AM
I need to have a look through the machine shop at work later this afternoon to see if I can find a 13/16" reamer, if not I will buy one later this week.
I am thinking get a hand reamer, but don't use the lathe under power; just use it to make sure everything is true. Thoughts?
Also, do you think that the old pin could be mounted in the tailstock to be used as a suitable guide?
As always, any advice appreciated...
P.S. I plan to drill and tap the inboard end of the stub axle where the helper springs attach, as one side is worn out; and no one seems to have any replacements :(
#5 nicklouse
  • 18,724 posts
Posted 15 February 2016 - 08:35 AM
loads of  dry ones out there. was a common switch to allow the use of rear shocks.
#6 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 15 February 2016 - 08:45 AM
It's a 13/16" long series parallel hand reamer you want, in place of the correct tool that is.
The shank is also 13/16" so will centralize on the roller bearing. I've not done it on a lathe before but I think there may be a centre hole in the reamer that you could use a running centre on in the tail stock. You may find that you will need to take a little more out to get the correct clearance.
#7 midridge2
midridge2
  • 1,794 posts
Posted 15 February 2016 - 09:18 AM
But if you use normal shocks is it not the wrong way round as the original helper springs pulls the arm back up.
#8 cheesebadger
cheesebadger
  • 226 posts
  • Local Club: MKMOC
Posted 15 February 2016 - 09:44 AM
Yeah. I think people used to fit front shocks to wet cars, but not seen or heard of anyone fitting rear shocks to wet cars.
I was planning to drill and tap the stub axle to accept a shoulder bolt to hold the helper spring, then I can just replace them when they wear out :)
Thanks for all your advice so far...
#9 Ethel
  • 26,107 posts
Posted 15 February 2016 - 09:48 AM
There has been at least one topic on diy reamers. Searching google images with the site: prefix would be a good way to find info.
Since getting the bearing and bush concentric is the main aim, I'd be inclined to work out a way of doing that. Like I said, I made up a dummy bearing that centres the reamer and can be removed to fit the bearing. Others have turned a pin in to a nose extension so the reamer can be fed in from the bush end.
Could you not knock up an adapter collar to convert a stub axle from shocker to spring fitment?
#10 cheesebadger
cheesebadger
  • 226 posts
  • Local Club: MKMOC
Posted 15 February 2016 - 10:00 AM
Yeah, I have done plenty of Google searching using the forum prefix, normally pretty successful. Which is what gave me the idea of the manual lathe.
Regarding the helper spring pin, sadly a collar would not work, as the wet pin diameter is smaller than the dry. The other obvious approach is to machine a dry pin to mimic the wet pin, but my current wet pin is otherwise in good condition.
