I remember seeing some threads on people using a Walbro in tank fuel pump.
seemed like a direct replacement for the standard item.
Any ideas where I can source one / or part number.
Posted 15 February 2016 - 03:51 PM
Posted 15 February 2016 - 04:04 PM
You can get them here
http://www.glencoelt...-pumps-in-tank/
Not sure which one you would need as it needs to fit the cradle for the internal pump hanger. I just got the replacement 'pump only' mpi pump from minispares and it works great
Andy
Posted 15 February 2016 - 04:16 PM
Thats the one!
255lph!
Many thanks!
Posted 17 February 2016 - 06:34 PM
Posted 17 February 2016 - 07:20 PM
I fitted the walbro to my injection tank, it is straightforward but not a perfect fit on the baseplate at the bottom of the return tube, most people probably just cable tie it in place, although I made a bracket up.
Yes I read about people needing to use a cable tie. Was your pump noisy?
Posted 17 February 2016 - 07:49 PM
Is it for an a-series engine or something different?
Posted 17 February 2016 - 07:53 PM
Aseries with k1100 head
Posted 17 February 2016 - 07:56 PM
Ah ok so an upgraded pump is a good idea. Yeah Walbro pump in an MPI tank is a standard upgrade for us VTEC guys and the Vauxhall guys so should be perfect for your conversion!
Posted 17 February 2016 - 07:58 PM
yip!
I am not sure whether I need the 190lph or the 255lph pump.
Do you need an MPi tank?
Posted 17 February 2016 - 09:03 PM
