Painting Mini Floor Protecting
Posted 15 February 2016 - 09:13 PM
Posted 15 February 2016 - 09:54 PM
There are various materials, but personally I use Schutz. This is black and sprays on. Then you can finish it in body colour, or not, as you wish.
Inside I paint with brush-on red-oxide primer, then spray with standard primer followed by top coat.
Posted 15 February 2016 - 10:05 PM
Posted 15 February 2016 - 10:36 PM
I used Shutza as above and then smooth gloss Hammerited over the top to make it easier to clean and add an extra layer of protection.
Posted 15 February 2016 - 11:22 PM
Posted 16 February 2016 - 01:35 AM
Schutz is very good it is all you will need..
Posted 16 February 2016 - 06:37 AM
Posted 16 February 2016 - 07:01 AM
Don't put Gravitex of Schutz onto bare metal, if it gets damaged then there is nothing to protect the metal.
Posted 16 February 2016 - 10:11 AM
Posted 16 February 2016 - 10:38 AM
Posted 20 February 2016 - 08:02 PM
Posted 20 February 2016 - 08:08 PM
Tigerseal or if you have access to it Proseal 870B2 which is an aviation sealant with anti corrosion properties. This is my favourite.
https://www.silmid.c...-95-type-i.aspx
