Blue Smoke On Startup
8 replies to this topic
#1 jamesquintin
jamesquintin
  • 1,017 posts
Posted 18 February 2016 - 12:45 PM
Hi all,
I'm starting to get a puff of blue smoke every time I start the car in the morning and it almost smells like a burnt out electric motor... A quick googling suggests worn valve guides, but its a brand new head?? I only put it on in August (part of my Cooper S kit)
Q
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 18 February 2016 - 12:48 PM
Does it have the little seals on the valve stems?
http://minispares.co.../LJQ101160.aspx
FS
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 18 February 2016 - 12:54 PM
On an injection it should have seals on all valves ( including the exhaust )
However, blue smoke on startup on a new head... I'd be getting in contact with the head supplier
#4 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 18 February 2016 - 01:12 PM
Hopefully its head related, as said take it back, minisport is it?
#5 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 18 February 2016 - 01:17 PM
If it goes away after start up my money would be on stem seals.
#6 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 18 February 2016 - 01:25 PM
+1
#7 jamesquintin
jamesquintin
  • 1,017 posts
Posted 18 February 2016 - 01:47 PM
I just stared it again after about 3 hours since the last start and there was no blue smoke...
WIll try again in the morning!
Q
#8 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 18 February 2016 - 04:29 PM
Have you got the correct oil level?
#9 spiguy
spiguy
  • 1,537 posts
Posted 18 February 2016 - 05:05 PM
You'll probably find it won't always do it. Mine puffs on startup most times, but sometimes doesn't do it even maybe for 2 or 3 starts. I think it depends on the position of everything when the engine switches off, eg if you have some oil getting past on a given valve, then if the engine stops with this valve shut, it can't dribble down into the cylinder.
