Clutch Slipping In 3Rd/4Th After Changing Starter Motor
2 replies to this topic
#1 AustinLeonardAutomotive
    Formerly IND00
  • 86 posts
Posted 19 February 2016 - 01:15 AM
Hello everybody!!  So the Minis in the garage for the winter, and Id like to tackle one of the problems it was having before I stowed it away.  If you saw my previous posts, I was having problems with my Mini not starting.  It ended up being a bad starter that was severely worn down.  So I took the starter out and got it professionally rebuilt.  After reinstalling it and putting everything back together the car started up great and I haven't had any problems since - except one.  The car drives fine and doesnt slip in 1st or 2nd gear, but once I get to 3rd and 4th, anything more than a quarter throttle and the clutch slips.  Its really frustrating especially when youre trying to pull out of tight twisty corners or get up to speed on the highway.  Could something have gotten on the clutch while I was replacing the starter?  I really hope I dont have to replace the clutch because thats more than I want to do this winter!!  :ohno:   Any help is appreciated.  Thank you!!
-Austin
#2 Coxie
Coxie
  • 461 posts
Posted 19 February 2016 - 06:45 AM
What clutch do you have. Verto (short stumpy clutch arm) or pre verto ( long clutch arm) ?
If it's pre verto is it adjusted properly on the return stop
Remove the return spring and pull the clutch arm towards the wing with minimal force to take up any slack.
Undo the nut that secures the return stop bolt and wind the return stop out till it touches the arm.
Then while holding the clutch arm out back the return stop of enough to fit a 20 thou feeler gauge between the stop and arm.
Then lock the nut off and re fit the return Spring and give it a drive.
If it's verto your probably looking at a new clutch to be honest. Either worn or contaminated.
Edited by Coxie, 19 February 2016 - 07:02 AM.
#3 AustinLeonardAutomotive
    Formerly IND00
  • 86 posts
Posted 19 February 2016 - 09:31 PM
It the pre-verto clutch so hopefully adjusting it will fix the issue.  Thanks!
-Austin
