The knuckle has a 12mm spacer on it. Looks like the same shape as a little exhaust cotton reel mount.
I plan on fitting the knuckle with 7mm spacer (Part number GSV1264) normally intended for the front on later cars as the normal knuckle (Part number GSV1118) has no spacer.
Should this be ok?
Will the front knuckle fit in the rear trumpet?
Will the 5mm difference have any consequence?
Alternatively, do I use the GSV1118 and add washers, if so how many washers?
Mike.
Edited by MikeRotherham, 19 February 2016 - 12:20 PM.
