I am trying to change the pipes from the brake master cylinder down to the bias pressure thingy on the bulkhead. However access is extremely limited!
I have tried to remove the brake servo to get at it properly, and this is where I have got stuck. How exactly do you remove the servo? I have undone the two nuts securing it to the bulkhead crossmember, is it then just a case of undoing the bolt that goes through the bulkhead?
I have tried to follow the haynes manual, and it seems more concerned with dismantling the servo rather than just raising it a few inches for access.
