Thanks Nick
Gearbox Advice
Posted 19 February 2016 - 05:26 PM
Thanks Nick
Posted 19 February 2016 - 05:29 PM
Doesn't look too pretty. I'd say these need replacing. Won't be hard to find some good second hand replacements.
Posted 19 February 2016 - 06:18 PM
I doubt you'd notice it, but being 3rd gear, as Stiggytoo has said, finding a new or better one won't be too hard.
Was the nose spigot / bearing between 1st and 3rd motion shaft really worn bad? If not, you may need to check the tunnels in the case between the Main Shaft and Layshaft are in fact parallel. Not too common, but I have found the odd one that's out. They really need to be within 0.002" at the very outside.
Posted 19 February 2016 - 06:26 PM
It is machined in during the manufacturing process as part of the design to allow easy recognition... single groove and double groove types are NOT interchangeable
Posted 20 February 2016 - 05:16 AM
I don't think it's the IDing he's referring to, but the wear in the teeth.
Posted 20 February 2016 - 12:35 PM
Ah yes I can see it now, a slightly different "flat area" on the tooth flank, that looks like a gear of a different helix has been mated together have you got the corresponding mating gear, you should see similar wear on the opposite flank same side.
Posted 20 February 2016 - 12:47 PM
Nick cam you post up a photo of the entire gear set on to here ?
Edited by MRA, 21 February 2016 - 02:03 AM.
