Revolution Wheels
8 replies to this topic
#1 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted 21 February 2016 - 11:31 AM
i am going to fit some revolution wheels can I use the wheel nuts that have come off my minilites
or do I have to use revolution wheel nuts
any help please
#2 nicklouse
  • 18,697 posts
Posted 21 February 2016 - 12:01 PM
Yes No Maybe!
Depends on the year of manufacture as to what nuts are required.
Without this info (picture) the correct info can not be given.
#3 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted 21 February 2016 - 12:27 PM
photo attached
mini is 1986 standard hubs
#4 MrBounce
MrBounce
  • 2,661 posts
Posted 21 February 2016 - 12:42 PM
Use the Revolution Nuts. It's what they're designed for.
Don't forget that the wheels on the car are the 4 things that keep you in contact with the road. If you use the nuts from your Minilites, then you could be making your car very dangerous to drive. Take a look on Google images at a set of Revolution Nuts and compare them to your Minilite nuts. Chances are they're quite a bit different - the Revolution nuts with their flat edge look totally different to the standard Rover Minilite nut which has an angled shoulder.
#5 MrBounce
MrBounce
  • 2,661 posts
Posted 21 February 2016 - 12:47 PM
Example as below:
Rover Minilite nut
Revolution RFX Nut
A good piece of advice I was once given re safety critical parts was this: "If there is any doubt, then there is no doubt. Use the right bit"
Edited by MrBounce, 21 February 2016 - 12:54 PM.
#6 MRA
MRA
  • 7,607 posts
Posted 21 February 2016 - 12:55 PM
They are NOT interchangeable !
#7 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted 21 February 2016 - 12:59 PM
have just found this on huddlefield spares
for rfx wheels???
#8 Ivor Badger
Ivor Badger
  • 846 posts
Posted 21 February 2016 - 01:42 PM
I eventually realised that you were meaning rover lookalike minilite and not the real thing. The answer is no as the studs won't even reach to the outside of the hub. real Minilite nuts don't fit either as they are much larger diameter in the tube part over the stud. So just buy the correct nuts.
#9 mini1955
mini1955
  • Area Managers
  • 542 posts
Posted 21 February 2016 - 01:50 PM
thanks for all the help
