Linered or not?
3 replies to this topic
#1 vincent w
vincent w
    Starting My Mini Up
  • 4 posts
Posted 21 August 2006 - 05:50 PM
Got hold of a block the other day. To me it the cylinders looks linered? I might be wrong since this is the first A-series engine I have had...
On the other hand, looking at the one Bill Sollis rebuilt on the minifilms dvd, that has the same linered look before they sent the block off to be planed and rebored...
Attached File  DSCN1682_edited.JPG   116.4K   30 downloads
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 21 August 2006 - 06:11 PM
Difficult to tell with all that crud
Best way to see liners is from the bottom of the block, it can be seen (most of the time) protruding from the bottom of the bores as an aprox 1.5mm thick cylinder.
Cleen up the surface better, you might be able to see it better.
Edited by Mini Sprocket, 21 August 2006 - 06:12 PM.
#3 vincent w
vincent w
    Starting My Mini Up
  • 4 posts
Posted 21 August 2006 - 06:17 PM
ok
I will a look from the bottom end when I have dismantled it that far, and then had it all cleaned up!
cheers mate!
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 August 2006 - 11:06 PM
Could be, but it could also just be the ghost of the gasket. As Sprocket says, look underneath.
