Revs Dropping at idle
4 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 21 August 2006 - 08:45 PM
Hi All
I recently had my Mk1mini cooper (twin carb HS2's) tuned, both ignition timing and carburettor.
The problem at the moment is that when the choke is fully in (warm engine), the engine revs increase/decrease, and this continues to cycle. It is quite noticable when the engine is at low idle. It isually takes around 20-30 seconds or so for the idle speed to increase/decrease noticably.
When the idle speed drops, the engine sometimes cuts out and I then need to apply a small amount of choke to keep it running at the traffic lights.
The tuner guy said that this could be the fuel pump not delivering the required fuel pressure to the carbs, or possibly a sticky or worn needle valve in the float chamber.
Does anyone have expreience of this, and what are the likely causes? Also, will adding a small amount of choke damage the engine?
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 21 August 2006 - 09:08 PM
choke just re-jimmys the fuel air mix and pops on some revs. so unless you runnning really reallllly rich there shouldn't be a problem. just means when you take you feet off the pedals your mini will keep going.
don;t know about the other stuff mind.
#3 bananaman
bananaman
  • 522 posts
Posted 22 August 2006 - 06:43 AM
If it doesn't do it with the choke out, it's not the fuel pump, you use more fuel on choke with it out.
You running an electric pump?
Possible that the idle screw settings on your carbs are not the same, or a sticking needle.
Whats your idle speed set to, maybe it's too low. I seem to remember a mate who had his set too low and the ignition systen used all the power from the dynamo not leaving enough to run the electric pump properly, hence no fuel and it cut out.
To be honest, it's been so long since I played with twin carbs I am just guessing.
You could try another tuner, see if he comes up with the same answer as the first.
Tony
#4 mk=john
mk=john
  • 1,167 posts
Posted 22 August 2006 - 07:58 AM
Hi
Thanks for the response. The fuel pump is the electric typw mounted on the rear subframe. This looks brand new as the car is reconditioned. However, the carbs are the original ones.
If I found the float chamber needlea are sticky, what is the best way to clean and lubricate them? What is the total process i need to go through if the needle valves are sticky?
John
#5 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 22 August 2006 - 08:08 AM
sounds like a air leak to me
this normmally causes the engine idle to be iratic
it is normally caused by the inlet manifold not sealing there are a number of reasons for this
the inlet manifold flanges are thicker than the exhaust manifold flanges
the inlet manifold is not tight
or there is a split in a breather pipe
or a few other just check its all tight
a easy check is to run the engine and spray wd40 on the manifold where bolts the the head if the revs
increase proves there is a air leak at the manifold
hope this helps
