Reconditioned Mpi Engine And Gear Box....
6 replies to this topic
#1 wozzer1340
wozzer1340
  • Just Joined
  • 124 posts
Posted 27 February 2016 - 01:19 PM
I've got a reconditioned MPI engine out of a Cooper Sportspack, engine and gearbox are still split. There is also the receipt for just under £800 worth of work, the engine is completely standard... Any ideas what it should be worth?
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 27 February 2016 - 01:42 PM
What work was actually done?
Any warranty left?
Who did the work?
#3 wozzer1340
wozzer1340
  • Just Joined
  • 124 posts
Posted 27 February 2016 - 02:09 PM
I'll dig the receipt out, as far as I can tell the short engine was completely reconditioned. The gear box also looks like new and a centre oil pick up and new 3.2 ratios have been fitted....
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 February 2016 - 02:17 PM
You don't get much reconditioning for £800 ;)
#5 Steve220
Steve220
  • 5,055 posts
  • Local Club: BMC
Posted 27 February 2016 - 02:38 PM
New pistons? What was the mileage before the recondition?
#6 wozzer1340
wozzer1340
  • Just Joined
  • 124 posts
Posted 27 February 2016 - 04:04 PM
Work was carried out by RTZ transmissions and cost over £1400... I'm going to give them a ring Monday to check exactly what has been done to it. Watch this space...
#7 wozzer1340
wozzer1340
  • Just Joined
  • 124 posts
Posted 29 February 2016 - 11:03 AM
I've spoken with RTZ the engine has had the following done to it,
New pistons, new rings, rebore possibly +40 depending on condition of bores, ground crank with new bearings, new bearings throughout including new cam shaft bearings. Head has also been fully rebuilt.
The gear box has been fully rebuilt and looks like it's just come out of the factory. All the work was done approximately 2+ years ago and it has been stored inside since then.....
