Which Type Of Wire Terminals And Crimper?
16 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 28 February 2016 - 08:59 PM
What is the best method for adding connectors/terminals to wires.
I have always used the colored insulated terminals with a cheap set of thin crimpers. It is very neat at a all.
I was looking at crimpers in a store today, i could make my mind up.
I saw a set of thick crimpers which crimp evenly along the insulated connector.
I also say a set of thick crimpers for uninsulated terminals, looked great.
Which type are best and are there any other alternatives?
#2 FlyingScot
FlyingScot
  • 2,675 posts
Posted 28 February 2016 - 09:08 PM
I use uninsulated type with shrink wrap around the connector.
FS
#3 Domneon
Domneon
  • 720 posts
Posted 28 February 2016 - 09:23 PM
I convert Police cars at the Peugeot SVO and we use a variety depending on the location on the car.
We use a lot of the superseal type connectors which have terminals that require these: http://www.vehicle-w...t-crimping-tool
And for pre-insulated spades, eyelets etc :http://www.vehicle-w...chet-crimp-tool
But it does depend on what connector or terminal you are wanting.
#4 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 28 February 2016 - 09:54 PM
My personal thought is solder with shrink wrap. Never liked crimp on terminals. You are never going to have a problem with a resin core soldered joint.
#5 Domneon
Domneon
  • 720 posts
Posted 28 February 2016 - 10:02 PM
Built 1000s of connections with purely crimping on the police cars without any problems. As long as the crimp is fine, it's not going anywhere.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 February 2016 - 01:26 AM
With solder you do have to be careful to solder quickly and get the heat out so the solder does not wick up the stranding.  With crimping you need to make sure the tool is set up correctly.
During the past year I purchased the crimpers in the link below.  They come with changeable dies to handle most crimp terminals you are likely to run into.
http://www.amazon.co...s/dp/B00TB0ULUE
#7 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 29 February 2016 - 08:35 AM
Solder does not like vibration. You'll find factory car looms, even modern aircraft (from airliners to military jets) use just crimps.
#8 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 29 February 2016 - 12:05 PM
and f1 cars.
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 February 2016 - 01:14 PM
In defense of soldering... yes, it doesn't like vibration.  However, when the solder is not allowed to wick up into the stranding and the joint is supported by heat shrink tubing, vibration of soldered joints is not really an issue.
The main reason given for preferring crimp vs solder is associated with consistent results and operator skill.  A properly set up crimp tool provides consistently good connections while soldered connections are highly dependent on the skill of the operator.  Soldering is also difficult in the field where there might not be electric power.  Vendors I deal with at work have provided me this information and given it as the main reasons why crimping is almost the only connection used by the U.S. military.
I use both connection types depending on the situation and conditions.
#10 MRA
MRA
  • 7,607 posts
Posted 29 February 2016 - 10:42 PM
urgh....  solder on a car ?  not a good idea, no professional wiring harness manufacturer would use soldered joints at all !  it would NOT pass FDVP testing and qualifying.
Solder forms a brittle joint as it cannot be controlled and will "wick" up the wire to a convenient point where it will fatigue.
secondary harmonics on a modern car can reach 70hz and wiring can fail at the frequency if not made correctly.
#11 MRA
MRA
  • 7,607 posts
Posted 29 February 2016 - 10:47 PM
Doug I understand what you are saying and soldering or crimping can have it's positives and negatives, soldering because of fatigue failure (more so on a turbo car) and crimping which also has to be done correctly..
Not many people know that a crimp has to apply a certain compression load on the wire strands, enough to keep out air between the wires (gaps lead to corrosion) and over crimping causes the strands to work harden and then fail, the solution is to use the correct crimping tool for the correct type of crimp for your wire and the crimping tool should be calibrated.
#12 MRA
MRA
  • 7,607 posts
Posted 29 February 2016 - 10:51 PM
Quote
Quote
I am pretty sure I saw a British REME VE using a gas soldering iron a few years ago, as some of the 38999 MIL connections are soldered terminals, the difference is these are protected by the use of a backshell, these support the wire over a pre determined distance.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 March 2016 - 07:53 PM
I always crimp the plain 6.3mm lucars and then run solder into the lucar and cover with the slide up over clear plastic covers
#14 floormanager
floormanager
  • 791 posts
  • Local Club: Mini Club Sussex
Posted 02 March 2016 - 08:02 PM
I second the ratchet type, with the correct connectors.  Class connections
#15 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 02 March 2016 - 09:46 PM
There is no problem with solder on a car if done properly.
Also, what about all of your electronics that are soldered???  Car stereo, electronic engine systems, onboard computers etc....  They are full of soldered components and I don't see them fatiguing and failing through vibration.  Just think of the amount electronics in modern cars!
If the job is done rubbish then you are going to have problems just like if you don't crimp a connector properly, it's all down to the skill of the person doing the job.
