The most comprehensive documentation for DC wiring that I've found is in the guides for marine wiring. My understanding is that solder is only acceptable in marine wire situations when it is used for the connection, but not for mechanical support of the wires. I.e. if you pull on the wire, it is not pulling on the solder, but on another support. That can be a clamp, crimp, or shrink tube.
I found this page to be quite useful:
http://www.pbase.com...ire_termination
If you think crimps are not strong, check page 5 of the above page, where he hangs 95 pounds of boat anchors from 2 pieces of 12gauge wire that are crimped together.
And see about halfway down page 5: http://www.pbase.com...mination&page=5
for a discussion of crimp vs solder+crimp vs solder.
For wiring, I prefer to use marine double crimp wire lugs, with an appropriate ratcheting wire tool.
I use nylon double crimp wire terminals:
http://www.amazon.co...on double crimp
And I use this crimper:
http://www.amazon.co...rine crimp tool
And I use this wire stripper:
http://www.amazon.co...MHVPY0MEXY0C7Y9
If you properly strip the wire and install the crimp terminal, there will be one crimp holding the metal of the terminal to the copper wire, and then another crimp that will hold a shoulder of the crimp terminal to the insulation of the wire. The copper should just protrude to the end of the barrel, visible but not exposed at the lug/blade/etc end of the crimp. The insulation should enter the wider part of the metal collar on the crimp, but should stop at the funnel, with only copper entering the narrower part of the terminal. On page 5 of the pbase article referenced above, it shows a cutaway of what good and bad crimps look like. With a good crimp, the separate strands of copper will nearly fuse together, creating a nearly solid mass of copper that will prevent moisture from wicking up. A good, brazed, crimp terminal will not split apart, and will create a strong hold on the wires.
If I am doing work in a wet place, I also use adhesive lined shrink tubing. I've been using this one below, though I found that my local electronics store has a better selection:
http://www.amazon.co...r shrink tubing
To shrink the tubing, I use an inexpensive heat shrink gun, though my butane soldering iron also has a heat shrink attachment that works in a pinch.
http://www.harborfre...1112-96289.html
And when done, I make sure to label both ends of the wiring, I use this labeler:
http://www.amazon.co...ire label maker
With this tape:
http://www.amazon.co...ire label nylon
Also, for wire, I have found that the automotive stores sell poor vinyl insulated wire. I spend a bit extra, and get GXL or TXL wire, which has a much more supple insulation, which lasts longer, and is rated for higher temperatures. The TXL insulation is better than that vinyl wire you get at the auto shop, AND it is significantly thinner, meaning you can fit more wire in smaller space than normal.
I have made extensive use of these kits:
http://www.wirebarn....olet_p_480.html
Edited by zerobelow, 03 March 2016 - 02:17 AM.
