Washer Bottle Position ?
Posted 29 February 2016 - 03:31 PM
Now my question is apart from the boot area where else can I put it. I was thinking of making up a bracket and attaching it to the rear seat inside the car ?
Posted 29 February 2016 - 03:34 PM
under the front wheel arch with a funnel sticking through the inner wing?
Posted 29 February 2016 - 07:46 PM
Posted 29 February 2016 - 07:49 PM
Posted 29 February 2016 - 07:52 PM
This is one of the best things I've seen just need to decide where it would go. Hmmmm
Posted 29 February 2016 - 07:56 PM
You could put it in front of the passenger somewhere some how
Posted 29 February 2016 - 08:13 PM
Well I've just paid for one so guess I'm going that route haha. There is the two fixing holes for the pedal box on the passenger side just below the crossmember could put it there or on the passenger inner wing ?
Posted 29 February 2016 - 08:20 PM
I put mine on the LH side of the passenger inner wing just in front of the roll cage hoop vertical and low enough that it is easy to re-fill.
Posted 29 February 2016 - 09:08 PM
That's what I was thinking of will be out of the way but still useable
Posted 29 February 2016 - 11:16 PM
In the boot the same as on later Minis
Posted 02 March 2016 - 10:36 AM
Other than the boot.....
Posted 02 March 2016 - 11:04 AM
Wherever you put it it needs to be easy to re-fill.
Posted 02 March 2016 - 11:14 AM
I suppose as long as you can get a piece of pipe with a funnel attached to it you should be ok.
The bag holds a lot more than the mk1 bottle
Posted 02 March 2016 - 11:24 AM
I currently have the washer bottle that sits on the clutch side of the engine bay and I want to move it so I can install a small battery in its place.
can I ask about this battery. what will it be doing and why does it have to be in the engine bay?
