Spacered Drums And 3/4Inch Spacers Or None Spacered Drums And 1 3/4?
Posted 01 March 2016 - 09:08 PM
May sound like a strange question i know
I'm buying new rear drums for my car as I have no idea when they were last changed and are begining to get a lip. I've been running with them for 7 years. Currently have spacered drums
I also want to space my wheels out an additional 20mm to fill the arches perfectly.
Now do I fit new spacered drums with a small spacer?
Or
Non spacered drums and a larger spacer?
What's the best choice for suspension is it is purely what I fancy?
Thanks in advance, hope this isn't a stupid query
Lawrence
Posted 01 March 2016 - 09:23 PM
The spacers that have the screw on stud extenders are lethal. And then consider studs that are available. They are only so long.
Posted 01 March 2016 - 09:37 PM
I've reasearched into the most ideal stud length and minispares have them that will fit the configurations I stated. And of course stud extensions are a recipe for disaster.
I'm angling towards the smallest spacer possible as logically have a built in one would be more secure.
Just wondered what people's opinions were on the subject of that
Posted 02 March 2016 - 05:49 PM
If you can get the correct length of studs from Minispares then they should be decent quality. There have been quite a few reports of poor quality wheel studs turning up from various sources so worth checking very carefully they are made of suitable material.
I would agree, use drum with built-in spacer and the thinnest additional spacer possible.
Posted 02 March 2016 - 06:32 PM
As suggested definitely the spacered drums and smallest spacers.
I was intending on running some Metro offset wheels on one of my GT's so required the extra spacing for clearance and was going to go with this option.
Joe
Posted 02 March 2016 - 07:16 PM
They are good quality, however first check they will fit your hubs as some are larger in diameter
Posted 02 March 2016 - 09:19 PM
And they should fit fine as my current ones are the already spaced drums that it refers to in the description
Thankyou for your recommendations
Lawrence
Posted 03 March 2016 - 08:18 AM
the mpi sportspacks left the factory with spaced drums and an 8mm spacer
Posted 03 March 2016 - 12:02 PM
My Mini has a spaced drum and 3/4" spacers. Im having to use the longest stud you can get which took several attempts to get right as people kept selling me the wrong lengths! People will probably say you will suffer premature bearing failure but ive never had any issues.
Posted 03 March 2016 - 01:41 PM
without mentioning the wheel spec you comment means nothing. as the offset of the wheel will effect the loads.
lots of Positive offset will set the wheel back where it should be and then adding width and changing the ET can leave you with normalish loads. but just sticking a standard wheel out in the air will greatly increase the loads and reduce bearing life.
Posted 03 March 2016 - 04:15 PM
ET10 offset on my wheels
Posted 04 March 2016 - 09:10 AM
http://www.minispare...loy-wheel-only/
Posted 04 March 2016 - 11:10 AM
Always remember that the Mini suspension was designed to have 3.5" wheels with either cross-ply 5-20 x 10 or radial 145/80 x 10 tyres. The centre-line of the tyre on the front is the ideal suspension geometry, so any movement of the tyre centre-line outwards adversely affects the geometry. Now with 4.5" wheels with the same distance of tyre inside edge to body the difference is not really noticeable and even 5" don't make much difference. However, that is with the tyre to damper clearance the same.
So the aim in wheel selection is to obtain the best geometry.
Wider wheels are normally fitted, together with wider tyres, to increase road-holding and thus increase cornering speeds. These increased cornering loads put more stress onto the wheel studs, so that is more reason not to have spacers, unless they are the thin ones.
The best handling Mini I have driven recently was a 1997 MPI with the 4.5" x 12 Minilite wheels fitted with 145/70 x 12 tyres. It just felt so 'right', especially in the wet.
The important thing is to understand what datum offset is needed to get a wheel to fit without the use of spacers.
The factory did fit slim spacers in order to get tyre clearance on the rear radius arms and I have had to do this on my Cooper 'S' when fitting forest rally tyres with thicker reinforced sidewalls, but only 5 mm thick ones.
