7.5 Disc Brakes
Best Answer FlyingScot , 03 March 2016 - 04:20 PM
Which kit are you using? This one? http://minispares.co...AJJ4028MS.aspx?
FS Go to the full post
3 replies to this topic
#1 tamlamotown123
tamlamotown123
  • 95 posts
Posted 03 March 2016 - 04:03 PM
Hi am just converting from drums to discs with the Mini Spares Conversion Kit. Got a problem, I have built up the Hubs/discs in line with the Haynes Manual and found the hubs dont rotate very freely when I have nipped up the hub nut, the subframe is not fitted to bodyshell so I cant torque it fully up yet.
Will it resolve itself when its tightened up or does anyone think there's an issue?.
Appreciate any comments, thanks
#2 nicklouse
  • 18,998 posts
Posted 03 March 2016 - 04:16 PM
sounds like the bearings are not seated correctly.
or is something catching.
#3 FlyingScot
FlyingScot
  • 2,675 posts
Posted 03 March 2016 - 04:20 PM   Best Answer
FS
#4 tamlamotown123
tamlamotown123
  • 95 posts
Posted 03 March 2016 - 06:40 PM
Hi am using the kit you identified, Both outer races bottomed out on the centre lip and spacer rings are fitted, the seals fitted right way round too, the book says tap the seals "fully home" i've took that to mean a far as it will go ie touching the bearing, do you think it means flush with the ends of the hub face?
