Mpi Fault Code 13: Fuel Pump Relay Or Purge Valve Or M.i.l Lamp ?
9 replies to this topic
#1 eric.sen
eric.sen
  • 113 posts
Posted 05 March 2016 - 08:27 PM
Hello,
my ACR4 give me this fault code :
Code 13 : fuel pump relay or purge valve or M.I.L. lamp or communications
When I errase the code it disappear, but  I start the car it reappear....
On the actuator mode of the ACR4 I made a test of the relays, nothing was wrong...
Help :X
Sorry for my English speaking but I!m French...
#2 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 05 March 2016 - 08:41 PM
Is the car otherwise fine? Any running issues?
#3 eric.sen
eric.sen
  • 113 posts
Posted 05 March 2016 - 09:04 PM
Yes, the car is running fine,
Just when the engine is hot kangarooing on 2nd gear when I stay near 2000rpm ( I never find what was the problem...)
#4 FlyingScot
FlyingScot
  • 2,664 posts
Posted 05 March 2016 - 10:33 PM
Which pod and which lead are you using on your ACR 4?
FS
#5 eric.sen
eric.sen
  • 113 posts
Posted 06 March 2016 - 09:42 AM
Hello FlyingScot  :highfive:  ,
I'm happy to read you (I know that Injected Mini and code readers have no secrets for you ! )
Acr4 is number 30255400 (blue tranparent version)
Pod is number 30352800 (Multi Application Pod)
Lead is number 30214000
It read the fault codes, clear them; etc...
sometime it write "unable to etablish data communications check connections and retry"
But the ACR4 clear my fault code but if I start the engine this fault code come again...
Edited by eric.sen, 06 March 2016 - 09:45 AM.
#6 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 06 March 2016 - 08:12 PM
as you are not getting any other running issues, other than the kangarooing, I would not worry. If everything is ok then maybe you should stop looking for a problem? I speak from experience here :)
for the kangarooing, check the engine steady bushes to start with
#7 FlyingScot
FlyingScot
  • 2,664 posts
Posted 07 March 2016 - 04:01 AM
Are you selecting Rover > Engine > Petrol >MEMS 2J ?
Comms are always a bit hit and miss with MPI as the wiring is tightly bunched and poorly earthed.
FS
#8 eric.sen
eric.sen
  • 113 posts
Posted 07 March 2016 - 03:00 PM
MEMS 2J then 1300 Mini  and after that the ACR says "Self Testing" and that the ACR says it has found an ECU with MEMS 2J management
#9 tmsmini
tmsmini
  • 734 posts
  • Local Club: MOASF
Posted 07 March 2016 - 04:17 PM
You might check the connection at the purge valve. The clips on mine cracked and were not holding the connector in place properly, eventually they fell off.
I added a zip-tie.
It would be best to replace it, but this has worked for quite a while.
Edited by tmsmini, 07 March 2016 - 04:18 PM.
#10 eric.sen
eric.sen
  • 113 posts
Posted 08 March 2016 - 05:34 PM
I tested the purge valve today,
Résistance is OK
Connected it directly with 12V and can heard the movement inside.
