Reading Jdm Mini..
Best Answer hungdynasty , 03 April 2016 - 01:28 PM
I just took a picture of my ECU model, for your reference, 1998 Japan SPI with air conditioning.IMG-20160403-WA0007_zpsuvpmdhuj.jpg
Go to the full post
13 replies to this topic
#1 inim_repooc
inim_repooc
  • 417 posts
  • Local Club: not part of one
Posted 06 March 2016 - 03:56 PM
Looking at getting a reader.. Which pod / lead would I have to get for my 98 jdm mini? Also, would I be right in thinking that the obd port inside the car doesn't do anything? But has power running to it?
Also, in this day and age, I would have thought someone would have developed some sort of software interface that connects via USB that could replace the need for the sp readers..
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 06 March 2016 - 05:50 PM
Guessing this
If yours is a jap spec car it will be spi set up with a/c, so guessing it has the 3 pin plug under he bonnet.
since both spi and mpi cars where only made for about 4 years each and rover made there own system, and the knowledge died with rover.
Don't think there be a pc version, I could be wrong.
I use a sp4 on the mpi.
#3 FlyingScot
FlyingScot
  • 2,664 posts
Posted 06 March 2016 - 06:44 PM
I've updated the thread on SPi code readers have a look on the last page.
FS
#4 inim_repooc
inim_repooc
  • 417 posts
Posted 06 March 2016 - 07:13 PM
FS
Thank - does this mean that for ecu matters - treat it as a normal spi? (sorry to be a bit slow on this - just want to be certain before I start buying things!) I also found a thing called Psacn - think you have looked at before.. would this work for mine?
did the jap ECU get updated - which ecu do I even have?   (mems 1.6?)
Many thanks  -  I'll try and stop being annoying.. soon :)
Edited by inim_repooc, 06 March 2016 - 07:16 PM.
#5 inim_repooc
inim_repooc
  • 417 posts
Posted 06 March 2016 - 09:39 PM
Found a really good bit of documentation on the mems units that helped clear a lot of things up I think!
Sure you have seen it before, but if you search this..
Rover MEMS - MPi/SPi - MINIpeople.lt
Edited by inim_repooc, 06 March 2016 - 09:41 PM.
#6 FlyingScot
FlyingScot
  • 2,664 posts
Posted 08 March 2016 - 10:17 PM
FS
Pretty sure your late model JDM will gave a unique MEMS unit as your car has an SPi throttle body and the MPI style coil pack.
It should be a MEMS2J from memory which is why it has the OBD style plug can you read the part number on the MEMS to confirm?
FS
#7 inim_repooc
inim_repooc
  • 417 posts
Posted 08 March 2016 - 10:32 PM
FS
FS
interestingly, I found the 3 pin connector under the bonnet and I also have an OBD port which has power going to it - not sure if anything else does.. weird
#8 hungdynasty
hungdynasty
  • 175 posts
Posted 09 March 2016 - 10:14 AM
FS
FS
My car is 98 japan version, it use the 3 pin connector for diagnosis . The OBD type connector is probably just for airbag diagnosis, I checked it only has 3 wires connected, one for live power, one earth and one to airbag device.
#9 inim_repooc
inim_repooc
  • 417 posts
Posted 09 March 2016 - 10:17 AM
This makes sense aye :)
#10 FlyingScot
FlyingScot
  • 2,664 posts
Posted 09 March 2016 - 11:21 AM
Nice one. If you have the AMP 3 pin connector then you should be able to use a reader for the earlier MEMS.
Any chance of that part number of the ECU, it's good to document this for others?
FS
#11 inim_repooc
inim_repooc
  • 417 posts
Posted 09 March 2016 - 11:24 AM
FS
will try and find it for you :)
#12 hungdynasty
hungdynasty
  • 175 posts
Posted 03 April 2016 - 01:28 PM   Best Answer
#13 inim_repooc
inim_repooc
  • 417 posts
Posted 03 April 2016 - 01:39 PM
Totally forgot about this!  - just had a look to confirm and yes mine is the same ahah  :lol:
#14 FlyingScot
FlyingScot
  • 2,664 posts
Posted 03 April 2016 - 09:51 PM
Thanks! I'll stick it in my "green book" of misc fuel injection stuff.
FS
