Unleaded Conversion
Posted 07 March 2016 - 08:28 PM
Posted 07 March 2016 - 09:46 PM
Small machine/engineering shop in High Wycombe, CMK, can probably do the work. Should come up on google.
Posted 07 March 2016 - 10:05 PM
Posted 08 March 2016 - 06:53 AM
Where in London are you? I can highly recommend a place just south of London near Kingston Upon Thames. With the cylinder head off you could take the opportunity to replace valve stem seals and valve springs as well as have the head skimmed if there is some meat left on it.
Posted 08 March 2016 - 08:51 AM
Posted 09 March 2016 - 04:41 PM
Posted 09 March 2016 - 05:05 PM
Posted 09 March 2016 - 05:42 PM
I remember the hype when they first took lead out of gas. I haven't converted any of my many vehicles and I'm not noticing valve seat recession in any of them.
Posted 09 March 2016 - 06:17 PM
£400 ? i assume thats for everything ? not just valve seat
if your on a tight budget then source a second hand head with it done
to be honest on a 998 not to sure if i would personal do it but each to there own
Posted 09 March 2016 - 07:35 PM
Running without additive is unwise. Your own call, but very unwise.
Posted 09 March 2016 - 07:41 PM
If the vehicle in question has done many miles with leaded gas, the seats have become somewhat impregnated, not to mentioned work-hardened, and therefore are somewhat immune to damage from lack of lead in the gas.
Posted 09 March 2016 - 08:37 PM
Just add Castrol Valvemaster in the correct quantity each time you fill up. It is all you need and not expensive.
Posted 12 March 2016 - 10:03 AM
Ricardo an engine development company that is used by if not all definitely most engine companies in the UK and elsewhere did some development for Rover, they concluded that running a standard A series on unleaded without any modification or additive the valve regression rate was outside of required limits.
To put this in short hand, the valves regressed by over 1mm per 10,000 miles, this test was concluded on brand new engines and medium mileage development mules that had run with leaded fuel for some time, the minimum mileage on the mule engines was 15000..... additive will certainly help even if you rev the nuts off it, the best way ?
Well you have 2 choices,
1) additive,
2) valve seat inserts,
Both have their negatives and positives, but as above, if it is a perfectly running engine just use additive, keep enough with you in the boot though.
Posted 12 March 2016 - 10:11 AM
They aren't immune ... Just less immune ... And that depends how they are driven ...
Posted 24 November 2016 - 12:56 AM
Hope to bump this up to get an idea of how to tell If my head is already set up for unleaded..
It's a 1973 Mk3 with 998, and has the bypass installed to the water pump. -Is that indicative or totally
unrelated? I can't recall years timing as to whether mine was built for unleaded. So many other surprises on this one
as I tear it down that unless there are some serial/part number clues I'm lost. Hate to waste machine
shop $$$ if this one is good to go, and I get the impression that even looking at the seats straight on you
can't tell if they are hardened or not.
Any direction/advice will be greatly appreciated! --J
