Wiper Motor Parts Pic Or Info
10 replies to this topic
#1 olly33
olly33
  • 758 posts
  • Local Club: 42nd Street (back in day)
Posted 10 March 2016 - 11:26 PM
Hi,I need a pic or a diagram of the inside of the round 110 degree wiper motor.
I used 2 motors to make a good one,but think there are washers/shims/bush is missing on the arm that connects to the plastic gear,as there seems to much slop. The motor is slowing in a particular spot,and I think its because of this?
The rack has been stripped and cleaned,degreased so know that's not a issue.
Cheers if you can help as my Mot is immenient.
#2 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 11 March 2016 - 12:19 AM
https://www.google.c...ih=829&dpr=0.85
#3 brownspeed
brownspeed
  • 451 posts
Posted 11 March 2016 - 09:37 AM
I can't remember what was inside the motor.
A new plastic gear in the gearbox solved all my issues. don't have my car to hand right now, even if I did- removing the cover exposes the top side only.
from memory I think there was one cup shaped washer below the gear, then a circlip and washer on the underside.
as a quick mot fix-can you reduce the tension on the arms at all? or use the chrome arms- there bog all tension on them anyway.
Edited by brownspeed, 11 March 2016 - 09:38 AM.
#4 olly33
olly33
  • 758 posts
Posted 11 March 2016 - 09:51 AM
Chopper. Cannot find enough detail to see what parts make up the arm fittings to the gear in the motor on google bud.
I try having a look at the other spare I have and see if that motor spins any easier first.
I think now the main issue is when I clamp the motor to the car body,it's putting a bit of force on the guide tubes slowing it even more.
#5 olly33
olly33
  • 758 posts
Posted 11 March 2016 - 11:46 AM
I have the chrome arms already fitted. Going to check movement of the rack cable.
#6 brownspeed
brownspeed
  • 451 posts
Posted 11 March 2016 - 05:11 PM
rack cable should glide freely. try & degrease it all & get all the old degraded grease out of the cable & tube. Use a liberal handful of grease; & it will be handful- I don't think there's any other way to lubricate it all without covering yourself in it!
#7 62S
62S
  • 1,244 posts
  • Local Club: You must be joking!
Posted 12 March 2016 - 12:21 PM
I presume you mean the Lucas 14W type of wiper motor? The degree of sweep is determined by the gear wheel not the type of motor. Hopefully this exploded diagram helps.
#8 olly33
olly33
  • 758 posts
Posted 12 March 2016 - 07:47 PM
Brownspeed,I have done all that,wheels seem free too.
62s,That's what I am after,is there a website for the individual parts listed ? Cheers bud.
#9 olly33
olly33
  • 758 posts
Posted 12 March 2016 - 07:53 PM
Any idea what part 17 actually does apart from pushing onto the motor spindle when tightened too.
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 March 2016 - 11:44 PM
17 is the end float on the comm/drive, I used to nip then up until you feels light resistance and then back off 45degs, to tight will bind up the comm shaft
6ft/lbs is the maximum pull with a spring balance on the drive cable, thats the setting in the Lucas Manual
#11 olly33
olly33
  • 758 posts
Posted 13 March 2016 - 08:12 PM
Thanks for the info Kernow.
