Engine Mounts
20 replies to this topic
#1 pusb
pusb
  • 1,216 posts
Posted 16 March 2016 - 06:54 PM
What type of engine mounts should I go for?
Minispares have:
The captive nut type, which apparently make fitting easy:
http://minispares.co...px|Back to shop
Or the original shaped ones which are supposedly better fitting, and do their job better:
http://minispares.co...ic/21A1902.aspx
#2 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 16 March 2016 - 07:02 PM
The ones without captive nuts and then weld your own nuts on
#3 pusb
pusb
  • 1,216 posts
Posted 16 March 2016 - 07:07 PM
Unfortunately I cant weld!
#4 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 16 March 2016 - 07:12 PM
Know anyone that can? If not still go with the ones without captive nuts
#5 Batmini
Batmini
  • 378 posts
Posted 16 March 2016 - 07:14 PM
Standard mounts were always fine for me. Heard of issues with captive nuts, there's no 'wiggle-room' when fitting them. You have to be spot on or you knacker the threads.
#6 greenwheels
greenwheels
  • 691 posts
  • Local Club: Mini Fixers
Posted 16 March 2016 - 07:17 PM
When I tried to use a captive nut engine mount I found it very difficult to line it up so I could screw the screw in. I find it much easier to use the plain mounts.
#7 redboy
redboy
  • 333 posts
Posted 16 March 2016 - 07:40 PM
I've gone for originals. Never done them before and dreading it.
#8 pusb
pusb
  • 1,216 posts
Posted 16 March 2016 - 08:02 PM
Originals it is then!
#9 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 16 March 2016 - 08:10 PM
Originals every time.
#10 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 16 March 2016 - 08:13 PM
They created a solution for a problem that didn't exist. :lol:  :bah:
#11 MRA
MRA
  • 7,607 posts
Posted 16 March 2016 - 08:17 PM
Get some green garden wire and fashion your special tool for feeding the bolt into the correct position,
ALWAYS ALWAYS ALWAYS
bolts go downwards for safety if the nuts work loose the engine will still be held in place and alert you to an issue, if you fit the bolts going upwards and the fall out the engine can float around a lot, trap the battery cable and cause a thermal event
#12 redboy
redboy
  • 333 posts
Posted 16 March 2016 - 08:37 PM
Thermal Event oO sounds like an epic disaster movie.
Are there any good "how to" guides around you know of?
#13 MRA
MRA
  • 7,607 posts
Posted 16 March 2016 - 08:43 PM
Loads :-)  .... like my very own how to rebuild your automatic transmission.... ;-)
Edited by MRA, 16 March 2016 - 08:43 PM.
#14 jaydee
jaydee
  • 8,565 posts
Posted 17 March 2016 - 04:31 PM
Fit Standard type only
As above said, bolts go downwards for a reason
#15 redboy
redboy
  • 333 posts
Posted 17 March 2016 - 04:39 PM
Done my off side mount today while the rads out.
I witnessed a mirracle as I eventually got the bottom bolt back in from underneath!!! Praise the Lord.
Not sure if I will do the other one as I can't even see it, Never mind get to it.
