Hi, I have a 87 mini city
All my indicators worked fine, day before mot the passenger side lights stopped working completely.
Drivers side works fine, also hazard lights do not work.
Any ideas? Find it a bit strange it's just the one side of the car that is working.
I have checked the bulbs on the passenger side and they all seem fine.
Thanks in advance
Indicator / Hazard Light Problems
my_first_mini
, Mar 16 2016 09:32 PM
3 replies to this topic
Posted 16 March 2016 - 09:32 PM
Posted 16 March 2016 - 09:36 PM
Sure there's dozens of responses to this fault now.
Common points of fault are:
Hazard light switch, indicator switch and plug from column switch to loom.
Then earths, plugs behind grill for front loom.
Posted 17 March 2016 - 06:55 PM
Solved....strange as I was sorting my horn (wasn't working very well) cleaned up the bracket and connection and all works fine!
Posted 17 March 2016 - 09:47 PM
And the bullet connectors are right in that area behind the horn bracket, have you checked they are all clean including the headlights and the earth wires
