1993 Mini 1275 Carb model
I am about to fit relays to the headlights, I will be using 2 relays, in fused holders so each individual light is fuse protected with 10 amp fuses after the relay. I will be taking the live feed for the relays from the starter solenoid. Currently the headlight are individually fused, but I intend just using 2 wires (1 main & 1 dipped) to trigger the respective relays. The relays & their fuses will be fitted to the inner wing
Should the permanent live be fused at 30 amps, which is more than total current for all both dip & main beams together ?
My thought is that if something in the relays or the permanent live feed was to short, the circuit would be protected & prevent a possible fire, so if the worst happened & all the lights would fail it would be better than a fire !
Have uncovered some twisted wire connections already, so a bit of sorting out to do.
Any advice welcome.
John
