Retarded Cam Timing
12 replies to this topic
#1 speedwell1
speedwell1
  • 107 posts
  • Local Club: m4 minis
Posted 18 March 2016 - 10:11 PM
Ive got a leyland 648 cam in my car, , everywhere ive read says cam timing should be 100 atdc , ive checked it today and found it to be 111 atdc,
What effect will that have?
Im goong to time it in properly, think im going to move a tooth on and adjust with an offset key,
Does the cam " cog" move clockwise to advance?
Which way is the offset key fitted?
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 18 March 2016 - 10:39 PM
get yourself a proper vanier adjustable set then you can get it spot on
#3 Dusky
Dusky
  • 5,322 posts
Posted 18 March 2016 - 11:02 PM
With 11 degrees you can just skip the cam COG 1 tooth and it ll be fine.
#4 speedwell1
speedwell1
  • 107 posts
Posted 18 March 2016 - 11:09 PM
Isnt a cam tooth 18 degrees?
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 March 2016 - 09:04 AM
Yes, which is why you get offset keys in 1 to 9 degrees.
As you're timing is 11 degrees out, then yes you need to rotate the cam gear 1 tooth clockwise ( so it opens earlier ) but with the 18 degree shift, 7 degrees too early, so you then need a 7 degree offset woodruff key put in rotating the cam gear 7 degrees anti clockwise,
Always measure the cam timing turning the crank clockwise, never anti clockwise.
#6 mini13
mini13
  • 3,811 posts
Posted 19 March 2016 - 09:54 AM
bottom line is it will be pretty crap at 11 deg out, you can expect it to be in the region of 10-15% down on power
#7 MRA
MRA
  • 7,607 posts
Posted 19 March 2016 - 12:04 PM
HINT:  The offset cam woodruff key can be fitted either way...
#8 speedwell1
speedwell1
  • 107 posts
Posted 20 March 2016 - 11:50 AM
I thought the offset is to 1 side of the key so you put it in with offset different sides to advance or retard was wondering which way is which
#9 Swift_General
Swift_General
  • 871 posts
Posted 20 March 2016 - 12:27 PM
Edited by Swift_General, 20 March 2016 - 12:28 PM.
#10 Swift_General
Swift_General
  • 871 posts
Posted 20 March 2016 - 12:35 PM
The crank (and cam) turn in a clockwise direction when viewed from the timing chain end. Therefore if you want to advance the cam fit the key such than the offset part of the key that sits in the sprocket is offset in an anticlockwise direction (and obviously vice versa if you wish to retard cam).
#11 speedwell1
speedwell1
  • 107 posts
Posted 20 March 2016 - 01:40 PM
Thanks very much
#12 speedwell1
speedwell1
  • 107 posts
Posted 20 March 2016 - 04:33 PM
Out of interest would the following problems I ve been having been down the cam timing,
Difficulty starting particularly when cold
Poor performance, on the rolling rd car didnt want to rev at all,
Lower than expected compression
#13 MRA
MRA
  • 7,607 posts
Posted 27 March 2016 - 10:11 AM
Yes it could cause of the above issues, however so could other problems be causing those issues.
