Gearbox 22G333 Mk1 Cooper Or Cooper S
9 replies to this topic
#1 Dave27
Dave27
    Just On Tickover
  • 7 posts
Posted 19 March 2016 - 08:00 PM
Hi,
During a recent oil change on my Mk1 Cooper I notice the gearbox number is 22G333, Is this MK1 Cooper S or Mk1 Cooper ?
Were any 333 boxes fitted to the cooper or specifically cooper 's' ?
I know this is a 3 syncro box but is the 22G333 any different ?
Any help/advice would be greatly appreciated
#2 nicklouse
  • 18,585 posts
Posted 19 March 2016 - 08:10 PM
S but which?
http://mk1-performan...k/gearboxes.pdf
Have a read.
#3 MRA
MRA
  • 7,607 posts
Posted 19 March 2016 - 08:13 PM
  22G331 Casing Number 22G333 - 970/1275cc Cooper ‘S’, ‘B’ type
http://minispares.co...ers.aspx?1~4~33
Edited by MRA, 19 March 2016 - 08:14 PM.
#4 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 20 March 2016 - 01:59 AM
The 333 casing was mainly fitted to the 1275 S although a few 970's had it.
If you look on the casing, above the 333 there might be an X or Y and/or there might be a number stamped on the front of the casing on the small flat area about 6" to the left of the casting number.
#5 Dave27
Dave27
    Just On Tickover
  • 7 posts
Posted 20 March 2016 - 07:40 AM
Thanks for the help,
There does not seam to be stamps to the left but the stamps I can see behind the oil filter are :
      Y
    S14
22G333
MOWOG
In this arrangement.
The output shafts are U-Joint type does this mean these will be cooper S ?
#6 Dave27
Dave27
    Just On Tickover
  • 7 posts
Posted 20 March 2016 - 07:46 AM
Above link answerd the question.
#7 MRA
MRA
  • 7,607 posts
Posted 20 March 2016 - 12:39 PM
      Y
    S14
22G333
MOWOG
They are all UJ type as this just means universal joint or flexible if you like, they should be Hardy Spicers on this box, easy to tell the difference, HS joints where often called crucifix joints because of the cross in the middle, ie like this......
http://www.minispare...ic/27H7880.aspx
#8 62S
62S
  • 1,243 posts
Posted 20 March 2016 - 09:16 PM
A 333 can be fitted with a rubber coupling or Hardy Spicer diff. It depends on the age.
#9 MRA
MRA
  • 7,607 posts
Posted 21 March 2016 - 02:56 PM
Yes my mistake, you are correct.
#10 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 22 March 2016 - 06:07 PM
Pre 66 were rubber couplins. When twin tanks became compulsory they added the Hardys.
