Compression Ratio
16 replies to this topic
#1 Joe555
Joe555
  • 240 posts
Posted 23 March 2016 - 08:58 AM
Is 10.6:1 too high for a 1293?
#2 Swift_General
Swift_General
  • 871 posts
Posted 23 March 2016 - 09:01 AM
Depends. You will need to supply more info on engine spec.
#3 racingbob
racingbob
  • 3,061 posts
Posted 23 March 2016 - 10:04 AM
in my opinion probably not ideal but i wouldnt be to worried about it
if it was me i would take touch off the head if not fitted
 is it a fast road engine not used daily like mine
my engine is running over 11.1 again not ideal
mg metro engine stage 3 head etc
been on there for 12000 miles use v power 99 octane plus
millers octane been no problems and uses very little oil
been on there 3 years now
if i used it daily would have changed the head long ago
i have another head to go on to bring it back to about 10.1
which will fit when weather warms up
someone with more experience can give you more info
need your engine spec
but hasnt been a problem on my car so far with over 11.1
#4 Dusky
Dusky
  • 5,322 posts
Posted 23 March 2016 - 10:25 AM
All depends. The race engien runs like 14:1..
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,763 posts
Posted 23 March 2016 - 01:32 PM
What cam and rocker combination?
Ac
#6 Joe555
Joe555
  • 240 posts
Posted 23 March 2016 - 06:25 PM
Metro A+ engine, just been bored to 1293cc, SW5-7 cam, 1.5 rockers. HIF44, light flywheel, 35.6mm inlet-29mm exhaust valves, P21253 pistons. If the compression is too high what is the best way to reduce it. And if it's ok what petrol will I have to use or will I need additives.
#7 carbon
carbon
  • 2,590 posts
Posted 23 March 2016 - 07:10 PM
With your spec you should be OK at CR 10.6:1, but to get the best performance:
- only use a reliable 99 octane fuel such as Shell V-Power
- needs very careful set-up of timing and distributor advance curve
- make absolutely sure you don't run under load with lean mixture
Out of interest, how do you know it is 10.6:1?
#8 ACDodd
ACDodd
  • Mini Docs
  • 2,763 posts
Posted 23 March 2016 - 07:39 PM
I would be at 9.75:1 personally.
Ac
#9 Dusky
Dusky
  • 5,322 posts
Posted 23 March 2016 - 07:44 PM
Reduce it by either increasing piston dish ( costly) or by getting a dremel and increase the combustion chamber cc.
its not too hard to do this if you go slow.
#10 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 23 March 2016 - 07:48 PM
It will last longer with lower compression, but depends on how you drive it for how long and how may miles you do, more compession will give better power, but will put more stress on the engine,
a metro turbo ran 9.1 with boost and the factory offered a warrenty with them>> so i dont think you will be blowing head gaskets left right and center.
as above said race engine run upto 14.1 they race flat out for 20 mins and last but dont do 1000s of miles
#11 carbon
carbon
  • 2,590 posts
Posted 23 March 2016 - 08:07 PM
Ac
Agree that 9.75:1 is a safer option than 10.6:1
#12 MRA
MRA
  • 7,607 posts
Posted 23 March 2016 - 08:21 PM
A race engine typically has a large overlap that allows only clean mixture into the cylinder so doesn't get any ram effects due to the exhaust valve being closed, your road cam will close the exhaust earlier thus getting a bit of "ram air" effect in to the chamber thus the effective compression can be higher on the non race engine due to this effect, or at the very least it will be higher volumetric efficiency per CR.
#13 Cooperman
  • 23,309 posts
Posted 23 March 2016 - 10:30 PM
It will be fine so long as the distributor advance curve is correct and you always use a 98 RON fuel, or add an octane booster like Castrol Valvemaster Plus.
#14 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 23 March 2016 - 10:54 PM
If you have hardened valve seats you can just use unleaded, otherwise you will need an additive like ValveMaster.
#15 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 24 March 2016 - 12:08 AM
I followed AC's advice and reduced mine from 10.3-1 down to 9.8-1. Re-cut valve seats so they are slightly deeper and ground out the chambers slightly (rough as a dogs dinner!) also put my dizzy to Aldon to get the curve matched to the 266 camshaft. I can only get 95 unleaded so wasn't wanting to chance it and hopefully will get a little bit more life out of my poorly built engine! I did it bytheway!
