Hi all,
I'm new to the world of Mini ownership, but I've just completed an engine out spring clean, changing a suspect crankshaft oil seal and fitting a MED lightweight flywheel / AP racing clutch assembly and cleaned the engine bay etc.
The process of putting the engine back in has - so far - been quite simple. Engine mounts tightened, speedometer cable on and so forth, but the process of reconnecting the inner CV joints to the differential almost seems to easy...
When I took the engine out, I separated the top ball joints and pulled the pot joints away from the differential housing with a block of wood and some careful prising. This seemed more logical to me than separating the CV joint from the driveshaft itself.
Therefore all I have done is simply push the pot joints back onto the differential, ensuring they were on the splines, and then tightened up the ball joints again. I could see there is an oil seal inside the differential housing ends, so I assume this will prevent any oil from escaping from the gearbox.
The Haynes manual makes reference to ensuring there is a circlip retaining, but I am assuming this is making reference to the connecting the pot joint / inner CV to driveshaft connection, not the pot joint to the differential - I can't see this coming out by itself unless something horrendous has occurred at the other end!
Any advice kindly appreciated.
