A Sad Day For My Daughter's Mini At The Mot
39 replies to this topic
#16 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 29 March 2016 - 04:59 PM
Can you confirm that the cables should be free to move in those quadrants?
Just checked the Haynes manual and it says the timing should be 7 degrees BTDC with the vacuum pipe disconnected at 1000rpm. Should I modify this to allow for unleaded fuel?
disconnected but also plugged at the carb end ..
#17 PaulColeman
PaulColeman
  • 712 posts
Posted 29 March 2016 - 05:30 PM
I'm sure somebody told me a couple of years back that it should be 10 degrees to allow for the fact that it's running on unleaded fuel?
#18 David128
David128
  • 644 posts
Posted 29 March 2016 - 06:16 PM
I tend to do it by ear and revs. Test drive for no pinking, and pulling in all gears
Edited by David128, 29 March 2016 - 06:18 PM.
#19 PaulColeman
PaulColeman
  • 712 posts
Posted 29 March 2016 - 06:34 PM
Does the timing affect the emissions? i.e. will retarding the timing more than 7 degrees make the emissions better or worse or have absolutely no effect? Given that the CO is over double the maximum I need to get it down drastically!!
#20 David128
David128
  • 644 posts
Posted 29 March 2016 - 06:39 PM
too much advance will increase emissions dramatically, CO is usually mixture
Edited by David128, 29 March 2016 - 06:41 PM.
#21 MRA
MRA
  • 7,607 posts
Posted 29 March 2016 - 07:44 PM
Maybe glazed a bit on the linings and rough up the drums, and re-adjust after checking the wheel cylinders are free.
As in rough up both with ??? grit wet and dry?
this really isn't a terrible fail... you will get it sorted easy!
No I know, I was being over dramatic like my Daughter! It's the end of the world to her ;-) She has visions of missing the L2B where it's entered into the show and shine. The problem with the brakes is you don't know how good/bad they are without a way of testing them.
You do if you have an IPHONE as they have acelerometers in them and a simple app will give you braking efficiences...
#22 PaulColeman
PaulColeman
  • 712 posts
Posted 29 March 2016 - 08:15 PM
Now that's a good idea! I'm afraid at my age things like iPhones have passed me by (my phone was £17.99) but I'm sure one of my kids can get that for me.
#23 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 29 March 2016 - 08:32 PM
New calipers...on drum brakes?
Personally at this point I would do a disc conversion anyway
#24 PaulColeman
PaulColeman
  • 712 posts
Posted 29 March 2016 - 08:37 PM
It had new calipers on all 4 corners when we restored it 2 years ago, along with new shoes and a new master cylinder. A disc conversion is on the 'to do' list but as it's not my car I'm waiting for my Daughter to finish Uni (this summer) so that she can pay for it hahaha
Does it need a servo or do people just fit the discs without? There doesn't seem to be a lot of room in the engine bay to retro fit a servo and the last time I looked they didn't seem to be available to buy new.
#25 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 29 March 2016 - 09:06 PM
You probably mean cylinders ...
#26 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 29 March 2016 - 09:11 PM
There is space for a remote servo and kits are abailable but I wouldn't bother. I don't like the feel of the brakes with a servo fitted, but others will disagree so it does come down to personal choice. I would try before you buy if you can, I am sure someone local would have a servo setup you could compare with.
#27 PaulColeman
PaulColeman
  • 712 posts
Posted 29 March 2016 - 09:12 PM
Yes you're right - got disc brakes on the brain as I've just been looking at them!! That and old age :wacko:
#28 PaulColeman
PaulColeman
  • 712 posts
Posted 29 March 2016 - 09:14 PM
Presumably it still uses the original master cylinder if you don't bother with the servo?
#29 MRA
MRA
  • 7,607 posts
Posted 29 March 2016 - 09:29 PM
Yep I disagree.... I like the feel of a servo, it is a lot lighter but you can still get the response and you very quickly get used to them..... well some people do anyway ;-)
OCT 88 onwards they where all fitted with master cylinder combined servo units
#30 MRA
MRA
  • 7,607 posts
Posted 29 March 2016 - 09:35 PM
This is the combined unit...
http://www.ebay.co.u...agAAOSwZtJW-UjP
You would still require discs and hub assembly hoses etc... and rear drums would be my recomendation
