Hello guys,
Looking to make my own custom binnacle, the plan is to take the two Speedo and tacho clocks and chuck the fuel/temp gauge in the bin.
Then CNC a new mirror finish stainless steel plate that the clocks will mount to, but I have a Davies Craig temperature controller that will take place of the old temperature gauge, so should look good when it's fitting snug.
My question is can you split up the standard 3 clock gauge? Looks like it's all attached together, I haven't had time to pull the dash out and mess around as it's my daily.
A rough mock up until I receive the controller though the post is attached. I may look tacky at the moment but it will look alot better when done.
Temp controller;
http://www.demon-twe...pump-controller
Thanks,
