Dizzy Vac Pipe. Are They Needed?
12 replies to this topic
#1 Howie1000
Howie1000
  • 124 posts
  • Local Club: Cornish Mini Club and Mini7
Posted 29 March 2016 - 11:24 PM
Hi,
I have a metro 1275 engine in my mini, originally it had a vacuum pipe going from the dizzy to the SU carburettor. I now have a Weber carburettor, it has no where to put the vacuum pipe.
Any ideas as to what I should do? Is it needed? I have the engine running, but due to other work going on with the car, it's not ready for the road yet so I can't comment on the drive of it without the pipe.
Many thanks in advance 👍
#2 Ethel
  • 26,033 posts
Posted 29 March 2016 - 11:39 PM
It is, if you want any sort of fuel economy and you'd have to compromise on part or full throttle performance as with one input it can only be right under one condition..
#3 timmy850
timmy850
  • 3,381 posts
  • Local Club: MITG
Posted 30 March 2016 - 12:15 AM
The Australian Cooper S never had vacuum advance and they went pretty well on the road. There is a bit in the article here about the vacuum signal with Webers:
http://www.minimania...tyle_Carburetor
Edited by timmy850, 30 March 2016 - 12:43 AM.
#4 nicklouse
  • 18,662 posts
Posted 30 March 2016 - 08:05 AM
Hi,
if your Dizzy has one you should use it.
if you don't then you need to lock out the base plate and modify the bob weights to give a suitable advance curve etc.
or change out to one that have been modded to your spec or fit a mappable ignition set up.
#5 gazza82
gazza82
  • 3,017 posts
  • Local Club: TMF+
Posted 30 March 2016 - 12:18 PM
Fuel economy ... With a DCOE? Unlikely ...
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 30 March 2016 - 12:30 PM
Good point.
#7 MRA
MRA
  • 7,607 posts
Posted 30 March 2016 - 01:22 PM
10mpg is better than 8mpg ..... fuel economy is relative.
The distributor has a vacuum advance therefore it will be subject to atmospheric pressure, the advance curve will not be suitable for your application, you have a Weber carb, therefore the chances are you also have a lot of other mods so you need to get either an ECU, a re mappable distributor or a modified dizzy with suitable curve.
#8 Howie1000
Howie1000
  • 124 posts
Posted 30 March 2016 - 07:51 PM
Many Thanks for the replies guys.
This engine is a standard metro 1275, the dizzy is original to the engine,mit doesn't have points, the vacuum ran from the dizzy to a standard 1 3/4 SU carb, the only mods now are a Weber carb, K&N, LCB and RC40. The car itself is fairly sorted as its meant to be my MED1380 engine living under the bonnet, however that is now stripped and a project on its own, so for now, just to get the car back on the road, it's a 1275 metro engine.
I'm not running a servo, so there's a blanking bolt on the inlet, I suppose I could modify that to house the other end of the vacuum pipe if required??
#9 timmy850
timmy850
  • 3,381 posts
  • Local Club: MITG
Posted 30 March 2016 - 08:55 PM
Manifold vacuum is different to carb vacuum. Manifold vacuum is present at idle as the engine is consuming air, but the carb vacuum port is on the other side of the throttle butterfly so at idle you have no vacuum.
Some distributors are designed for carb vacuum, others for manifold vacuum and others for none. You should really keep the advance on the distributor as it was designed for.
#10 Howie1000
Howie1000
  • 124 posts
Posted 30 March 2016 - 08:56 PM
Actually........ The original,pipe ran from the carb,Minot he inlet manifold, that might cause more problems??
#11 Ethel
  • 26,033 posts
Posted 30 March 2016 - 09:32 PM
The carb vac advance is placed so it doesn't see full manifold depression with the throttle shut, it idles better with less extra advance.
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 March 2016 - 10:44 PM
At one stage they ran the MG Metro with inlet manifold vacuum, just to clean up the immissions if my memory serves me correctly, why not just run the HIF44 on the 1275 until your other engine is ready
#13 Icey
Icey
  • 1,552 posts
Posted 30 March 2016 - 11:12 PM
I was thinking the same assuming the OP has one to hand. The Weber won't be adding anything.
Edited by Icey, 30 March 2016 - 11:12 PM.
