Gear Selector Roll Pin Removal
21 replies to this topic
#1 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 31 March 2016 - 07:55 PM
Absolutely everything is ready to lift my engine out!
All really smooth.
But I just can't manage to remove the roll pin on the gear selector. I have tried various "tools" to punch it through,
Any tips?
#2 One step at a time
One step at a time
  • 282 posts
Posted 31 March 2016 - 07:58 PM
I've just removed one and it is a pain.
My method was with the right size drift and I knocked it out from below and up and towards the clutch plate.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 31 March 2016 - 08:02 PM
For once try a bigger hammer, I just bought one off these but yet to try it. looks the part.
http://www.ebay.co.u...T8AAOSwe-FU-i~T
eBay item number: 121911856896
#4 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 31 March 2016 - 08:09 PM
they look great!
#5 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 31 March 2016 - 08:10 PM
I suppose I really should have order the tool from minispares in advance.
#6 pusb
pusb
  • 1,216 posts
Posted 31 March 2016 - 08:11 PM
they look great!
I got one of these and it worked great. Only tricky bit is lining it up, but once you have that the pin comes out easily.
#7 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 31 March 2016 - 08:17 PM
Put in reverse gear.
Use the minispares punch or suitable sized punch (you can even use a drill bit (use the non drilling end to knock pin through).
Most important thing is that whatever you use its the right size so it doesnt go inside the roll pin and spread it.
Again, reverse gear and it knocks up towards the gearbox casing and you can grab it and wiggle for the last bit. Never had to buy a tool from ebay, looks like someone is profiting from something that shouldnt really be a problem.
#8 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 31 March 2016 - 08:24 PM
Alright! I approach it again tomorrow with the info provided above.
Thanks guys!
#9 David128
David128
  • 644 posts
Posted 31 March 2016 - 08:26 PM
and its the pin nearest the gear box. the rear most one is a rivet
#10 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 31 March 2016 - 08:31 PM
HAHAHAHAHA
That explains a lot!
I intended to approach the one nearest the gearbox, but i must of got disorientated when under the car and when i think about it was the one furthest from the GB. long day a work i guess.
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 31 March 2016 - 08:42 PM
No it's not, they're both roll pins.
#12 David128
David128
  • 644 posts
Posted 31 March 2016 - 08:48 PM
mine is defo a rivet
#13 Itsaminithing
Itsaminithing
  • 853 posts
  • Local Club: Not One Worth Mentioning
Posted 31 March 2016 - 09:06 PM
My guess is a previous owners bodge....
Should be 2 roll pins for the coupling -part number RSP1416 (& one on the other end of the gearchange rod).
Can be difficult to get out sometimes but i've never seen the need to buy a 'specialist' tool, just a big hammer & the right sized drill/drift/length of metal rod or whatever i had to hand.
#14 Spitz
Spitz
  • 1,716 posts
Posted 31 March 2016 - 09:11 PM
3/16" punch  ( not a tapered end )
Have car in reverse
#15 Icey
Icey
  • 1,552 posts
Posted 01 April 2016 - 12:28 PM
Be very, very careful if you use a drillbit. It's highly likely it'll shatter when hit hard enough and if you're under the car looking at it there's a chance a lump of it will end up in your eye. I'd go so far to say don't do it at all, just buy the correct size punch or the nifty looking tool that's now available on eBay.
