Sunpro Dials......
Best Answer dklawson , 01 April 2016 - 11:47 AM
This is a very common problem and it is not unique to the Sunpro gauge.
What you need is adapter TE5 from Mini Spares.  It's purpose is to prevent a mechanical temperature gauge expansion bulb from bottoming out inside the cylinder head.
Go to the full post
4 replies to this topic
#1 Howie1000
Howie1000
  • 124 posts
  • Local Club: Cornish Mini Club and Mini7
Posted 31 March 2016 - 09:51 PM
I know I'll probably get slated for buying the Sunpro gauges, but I need to use them for now.
The water temp isn't fitting, the probing bit at the sender end is quite long and doesn't leave enough to get the nut on tight. Also I don't have an oil tube for the oil pressure has anyone else had these problems with Sunpro, any ideas what to do? Cheers.
Attached File  image.jpeg   48.43K   3 downloads
#2 Dusky
Dusky
  • 5,322 posts
Posted 31 March 2016 - 10:11 PM
My gauge kit Came with everything ready to fit. The only problem was the water probe like yours. I made a small adapter to solve this, only need 5 mm more actually.
#3 Howie1000
Howie1000
  • 124 posts
Posted 31 March 2016 - 10:17 PM
What kind of adaptor? Cheers.
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 01 April 2016 - 11:47 AM   Best Answer
#5 Howie1000
Howie1000
  • 124 posts
Posted 02 April 2016 - 11:41 PM
That's great, the exact thing I'm after, thanks for that
