Spi Cooper Si Running Too Lean....!
Posted 01 April 2016 - 03:00 PM
I usually have problems as its a John cooper modded car, and that's with high CO and HC
This time it's reversed, very low CO at 0.01% very low HC 0047ppm but high lambda 1.14..
Have checked exhaust for air leaks...
What could cause it to run lean?
There is a hint of misfire at light throttle cruise too...and next to no soot in the tail pipe..
Any thoughts as I'm stumped?..
It has a Lucas Lambda from mini spares that's only done 1500miles Max, have a gen Bosch on order just in case..
Posted 01 April 2016 - 04:32 PM
Interestingly, when I un plugged it the reader still showed 403mV which I'm hoping is a limp home/pre set figure, however I thought it would be set a little richer..
Pinching each fuel line while wiggling the cable saw it swing to righ and lean but quite slowly.
I'm still within my 12 month warranty with mini spares so back it goes....
I only hope I've not done any serious engine damage running it lean..
Posted 01 April 2016 - 06:21 PM
whats the temp sender saying?
Posted 01 April 2016 - 07:59 PM
I suppose it was a cheats method of making it run a bit rich...
Posted 01 April 2016 - 08:17 PM
well it was just a thought, of course has the exhaust got a small hole in it? as that would mess it up just enough
Edited by minidaves, 01 April 2016 - 08:17 PM.
Posted 01 April 2016 - 08:33 PM
FS
Edited by FlyingScot, 02 April 2016 - 09:27 AM.
Spelling
Posted 02 April 2016 - 12:12 PM
The relay box checks out good...
