My Daughter's 1976 Mini 1000 failed the MOT on its drum brakes not being up to scratch and the handbrake was unbalanced between the rear wheels. I checked the handbrake quadrants and they're free and the handbrake mechanisms both seemed to work. However, I did find that one of the back plates was loose so I'm hoping that's cured the handbrake issue?
I also found a couple of the wheel cylinders had seized and I've now replaced them both. The shoes have plenty of life in them and I cleaned all the dust out before giving the shoes and drums a rub over with 120grit wet and dry. I reassembled it all, bled the brakes and readjusted them all. I took it out for a test drive and the pedal was going down to the floor. So I re-bled them all and readjusted them again and now they're better but it pulls to the right when I brake sharply. To be honest an emergency stop would be very difficult in that car!!
The master cylinder is less than 2 years old and if anybody has any suggestions about what else I can try I'd like to hear them.
Thanks, Paul.
