Edited by jameseddolls, 02 April 2016 - 10:27 PM.
Should My Front Tyres Be This Far Forward?
Posted 02 April 2016 - 10:26 PM
Posted 02 April 2016 - 10:30 PM
What have you changed?
No pictures showing.
Posted 02 April 2016 - 10:32 PM
Not sure on this one. The back tyres are ok, but both front tyres are not in the middle of the arch. Let me know your thoughts if it's a suspension thing or not
Picture attached
IMG_20160402_144936.jpg 30.92K
97 downloads
Posted 02 April 2016 - 10:49 PM
wondering if the front tie bar bush has collapsed & someone tightened up the slack ?
just a guess
as above if arch isn't on right , it will also make the wheel look in the wrong position
may be an idea to check the wheel base - if the car is standard / not lowered / or any special suspension on it
Posted 03 April 2016 - 12:08 AM
The side repeater suggests the arch is right, but the wheel looks forward relative to the shock-absorber, so I'd be looking at the tie rods.
Posted 03 April 2016 - 07:09 AM
I have the same problem with mine. Is it only on one side? my front left wheel is further forward than the right and I've been told that its most likely to be because the front subframe is slightly twisted possibly because of a little bump accident it might have had... i know the reason behind mine :/ don't let your friend drive you car round a car park!!! learnt the hard way!!! i put some adjustable tie rods/bars which helped push the wheel back but you'll have to ge the wheels alignment done.
Posted 05 April 2016 - 03:59 PM
Who put the arches on?
the arches were put on by the guy I bought the car from, so they have been on there for about 7 years.
Posted 05 April 2016 - 04:00 PM
oh no mine is on both sides, its very strange. Will have to investigate further. Wish one of you guys could come down and show me what im meant to be doing haha
Posted 05 April 2016 - 04:04 PM
just a guess
will have to take some pictures of the suspension when I jack it up over the weekend. will post them up and see what you think. Im no mechanic at all, but would love to learn little bits. The car does have adjustable GAZ shock absorbers, which me and my mate increased to make the ride height higher, as the front of the wheels were scraping every time I went over a slight bump or had full lock.
Posted 05 April 2016 - 04:20 PM
Sorry poor guess. As the big washer on the front is tightened till it bottoms out on the tie bar clamping the bushes in place.wondering if the front tie bar bush has collapsed & someone tightened up the slack ?
just a guess
You can not over tighten or take up any slack.
Posted 05 April 2016 - 04:26 PM
just a guess
I will take a picture of the weekend for your diagnostics. :)
Posted 05 April 2016 - 04:55 PM
Adjusting the dampers will not alter the ride height! Mart.
Posted 05 April 2016 - 08:21 PM
just a guess
not a poor guess - going from previous experience - cars coming in for mot
your assuming it has been assembled correctly in the past
I've even seen them with 2 bushes one side various washers to take up slack / adjust
often accompanied by a fresh wing
never underestimate the bodgy-ness of a previous owner / repairer
Edited by sledgehammer, 05 April 2016 - 08:25 PM.
Posted 05 April 2016 - 08:25 PM
not a poor guess - going from previous experience - cars coming in for motSorry poor guess. As the big washer on the front is tightened till it bottoms out on the tie bar clamping the bushes in place.wondering if the front tie bar bush has collapsed & someone tightened up the slack ?
just a guess
I would hope that people who are working on their cars have a Haynes manual and read it.
As that is the only thing we can go by.
I think I would have said "incorrectly assembled" rather than suggesting an impossible.
But another thing that has not been mentioned which nay have caused the issue is someone jacking the car up on the tie bars and bending them.
