Centre Binnacle Bulbs
6 replies to this topic
#1 hitch436
hitch436
  • 85 posts
  • Local Club: Box Hill, Mini Cooper Register
Posted 04 April 2016 - 12:45 PM
i am considering putting brighter bulbs in my centre binnacle however the only sensible answer i have had is putting led ones in, would that be a straight swap or would i have to do some wiring? also is there i can just get brighter normal bulbs from?
#2 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 04 April 2016 - 01:00 PM
Don't change the ignition warning light .. LED doesn't work and stops it charging.
You should change to higher wattage bulbs as these just mean the gauges get hotter and then the holders melt!
Have a look around on the "Trusted" Mini or Classic car spares websites .. (ie not fleabay!)
#3 hitch436
hitch436
  • 85 posts
Posted 04 April 2016 - 01:35 PM
i was only considering changing the ones that illuminate the numbers, the rest are fine, would i be able just to buy two and screw them in?
#4 JetBlackEreg
JetBlackEreg
  • 130 posts
  • Local Club: East Anglian mini club
Posted 04 April 2016 - 02:57 PM
I've got white LED's in mine for auxiliary gauges and panel lights. I'd recommend them.
#5 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 04 April 2016 - 03:05 PM
You could try http://www.moss-euro...dash-bulbs.html
Is you car positive or negative earth? LEDs are polarity sensitive
Edited by gazza82, 04 April 2016 - 03:07 PM.
#6 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 04 April 2016 - 04:33 PM
The MOSS bulbs Gazza posted the link for are about the only option in the U.S. for those of us with older British cars.  I personally have not invested in them but I have read reviews/discussions of them on other message boards.  So far people seem to be pleased with them.
Also as Gazza said, they are polarity sensitive.  I believe MOSS has them both, just make sure you buy the right ones.
#7 Scousemouse
Scousemouse
  • 358 posts
Posted 24 April 2016 - 03:04 PM
I've put a set of LEDs in mine this week..great but as GAZZA 82 says DON'T CHANGE THE IGN BULB,leave it as tungsten.
These are SCREW IN .MInes a 91,went in great,look great at night.
got them on FLEABAY as well, they are made to fit mini.
look for "CHARLIECCU"  Dash + Dial Lighting in Vehicle Parts & Accessories...£10.50 free P+P
   You get 4x5SMD bulbs + 5x8SMD forward facing bulbs for the warning lights BUT LIKE YOU'VE BEEN TOLD ..DON'T USE IN THE IGN BULB!!
also come in a choice of colours,
ALSO as GAZZA  mentioned NORMAL  CAPLESS LEDs are POLARITY SENSITIVE (only go in holder one way,you have to test them...reverse  them around if they don't light)
 BUT THESE SCREW IN LEDS HAVE BASES JUST LIKE STANDARD OLD MINI BULBS,SO ARE MADE EARTH TO SCREW BODY,so you can't go wrong :proud:
Edited by Scousemouse, 30 April 2016 - 07:13 PM.
