Running Rich Even Though Fully Leaned
8 replies to this topic
#1 Arthy
Arthy
  • 112 posts
Posted 05 April 2016 - 01:17 PM
I'm currently a bit baffled here.
I'm currently running twin HS4 and one side is running rich while the other is spot on.
The nut is fully leaned out and it is still running rich. I'm starting to think it is the fuel bowl as it is not as clean as the other and I can also see the slightest bit of fuel at the top gasket.
The carbs have been fully refurbished and the car pulls extremely well. You wouldn't suspect a thing.
Any help would be appreciated!
#2 nicklouse
  • 18,998 posts
Posted 05 April 2016 - 02:56 PM
too much fuel pressure?
different needles? which are?
engine spec?
air leak?
#3 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 05 April 2016 - 02:59 PM
Worn needle or jet?
#4 Arthy
Arthy
  • 112 posts
Posted 05 April 2016 - 04:07 PM
I can't see it being the needle type. The other carb is at a relatively good tune, with a good spark plug colour. But I'll have a look to see if the needles are odd.
I'll have a good look tomorrow. It's given me something to go on besides the fuel chamber float which I thought.
Thanks guys!
#5 carbon
carbon
  • 2,590 posts
Posted 07 April 2016 - 08:39 PM
Could be float chamber needle on one side not sealing properly, this would overfuel.
If you don't already have an in-line fuel filter fitted just before the carbs I would recommend adding one. You will be surprised how much rubbish it collects.
#6 Arthy
Arthy
  • 112 posts
Posted 07 April 2016 - 09:46 PM
You just pretty much summed up what I'm thinking, and hoping what it is. I actually had an issue with fuel spilling out of the other carb float chamber but after a quick clean its now fine. I'm just hoping its the same with the other one now. I did notice very slight fuel residue at the top gasket of the float chamber so it does point towards that.
Thanks for your help!
#7 Arthy
Arthy
  • 112 posts
Posted 08 April 2016 - 07:27 PM
So I took the float chamber lid off and checked to see if it was shutting off the fuel by blowing through it, which it was. After a 10 minute drive shes still running rich. I'm currently stumped here, I'm going to disassemble that carb and give it a clean and see if that solves it. Could it be the needle not centered?
Any other help would be greatly appreciated!
Edited by Arthy, 08 April 2016 - 07:35 PM.
#8 gazza01
gazza01
  • 644 posts
Posted 11 April 2016 - 09:10 PM
Dont they have a wax stat. If so could that be an issue if one fails?
#9 Arthy
Arthy
  • 112 posts
Posted 11 April 2016 - 11:41 PM
I recently bought a colour tune and got them both blue with only 3 flats or so to spare on the one side. I'm going on a good run next week so I'll see the condition of the plugs then.
They are not the wax stat type and the needle is centred properly as I checked a few days ago. But thanks for your help. Hopefully she's fine now!
