http://imgur.com/pnpIEoo
http://imgur.com/2FgHypr
http://imgur.com/pykXhf5
http://imgur.com/Df3lbSl
Thanks Dan
Edited by Daniel_moody25, 07 April 2016 - 04:04 PM.
Posted 07 April 2016 - 03:53 PM
Posted 07 April 2016 - 04:24 PM
Something doesn't look quite right about the gap between 3rd gear and the syncro. It may just be the camera angle though.
Either something isn't seated on the mainshaft correctly pushing the 3rd/4th gear syncro over or the 1st motion shaft hasn't seated correctly (bearing or baulk ring possible).
Or alternatively it's 1st gear that has been shunted over by something - as you know, there are fixed points on the mainshaft so it must be something in relation to those....
Posted 07 April 2016 - 04:34 PM
Posted 07 April 2016 - 05:23 PM
Get it all torqued up - it'll pull the shafts through the bearings further, leaving more space for everything to seat properly.
Posted 07 April 2016 - 06:40 PM
Just check the selector forks are still sitting correctly with the bell cranks.
Also, did you trial fit the 1st and 3rd motions shafts together on the bench before fitting them up in the case?
There could be an issue with the 3rd motion shaft nose bearing journal and / the the bearings itself and / or the same in the 1st motion shaft.
Has this gearset been together before?
Posted 07 April 2016 - 07:50 PM
Posted 08 April 2016 - 12:23 PM
