Top Arm Bearing Problem
7 replies to this topic
#1 andyt
andyt
  • 375 posts
  • Local Club: cooper register
Posted 07 April 2016 - 09:55 PM
I have been removing the bearings from the top arms tonight and have been welding an m10 bolt head into the top of the bearing then pulling it out using a socket, washers and a nut, now this worked fine for 3 of them but the 4th one the bearing has broken up leaving just the outer race  in the arm. How do i get this out without causing damage to the arm?
Andy.
#2 nicklouse
  • 18,618 posts
Posted 07 April 2016 - 10:01 PM
Using a drift tap it out from the other size. A slight angle on it can help get purchase.
#3 MRA
MRA
  • 7,607 posts
Posted 07 April 2016 - 11:56 PM
Preferably a soft drift made from brass to avoid damaging the arm.
#4 andyt
andyt
  • 375 posts
Posted 08 April 2016 - 06:01 AM
Will I be able to reach the bearing back edge from the other side? Don't know if my brass drift will fit through either.
I did think about carefully cutting a slot with a junior hacksaw blade so that I can get behind the remaining outer race.
#5 bikenutmart
bikenutmart
  • 579 posts
Posted 08 April 2016 - 09:57 AM
Try a dremmel if you have one. Mart.
#6 Stevie W
Stevie W
  • 1,203 posts
  • Local Club: P&SMOC
Posted 08 April 2016 - 10:26 AM
Hi Andy,
If you have an old flat bladed screwdriver that's long enough to reach the bearing cage from the other end you could use this. I had such  as screwdriver, and ground the sharp edges off of the tip before using it. Just use light hammer force to gradually tap it out. Just be careful not to dig into the arm metal surface where the bearing sits.
As mentioned above, a brass drift is the best thing to use as you'll not damage the arm bearing surface with this.
Cheers, Steve.
#7 andyt
andyt
  • 375 posts
Posted 08 April 2016 - 10:29 AM
My problem is that the roller cage has broken up and i'm only left with the very outer part of the bearing that sits against the arm.
Andy.
#8 MRA
MRA
  • 7,607 posts
Posted 08 April 2016 - 10:30 AM
Using a dremel is ok, just make the outer part thinner, then you should be able to pull it out using a pair of pliers or gently tap it out using a steel bar and a small hammer.....  gently being the word to focus on here.
