Fitting Twin Hs2 Problem
16 replies to this topic
#1 Ianm11
Ianm11
  • 93 posts
Posted 10 April 2016 - 12:20 PM
Hey more problems lol :D :D  Hope someone can help me anyway im restoring a mini i bought and im at the engine stage, almost have it complete and soon was hoping to give it a quick start on the floor while its out of the car incase theres any leaks etc. Now the engine is a 12H 1275 which originally had a single carb fitted and someone already had a 3 branch exhaust manifold which im using again just to start it. I bought a pair of twin hs2 carbs from a guy in Italt and attempted to bolt them on with the exhaust manifold but the heatshield on the carbs is fouling on the exhaust so i cant get the carbs to sit against the head. Anyone ever come across this? Ive attached some photos(not great) that might give you an idea
Thanks again for everyones help
IanAttached File  IMG_9267.JPG   117.19K   35 downloadsAttached File  IMG_9269.JPG   119.31K   25 downloadsAttached File  IMG_9275.JPG   105.41K   18 downloadsAttached File  IMG_9268.JPG   112.94K   14 downloads
#2 mad4classics
mad4classics
  • 200 posts
Posted 10 April 2016 - 12:41 PM
Staring hard at the first picture I think you've got a 12G299 manifold which is not for a mini. You need a manifold with a 30degree inclination. You're going to need the float bowls on the carbs with the same inclination too, but you can just change the float bowl mounting rubber to do that.
Edited by mad4classics, 10 April 2016 - 12:48 PM.
#3 Ianm11
Ianm11
  • 93 posts
Posted 10 April 2016 - 01:05 PM
I know the photos are not great. How would i go about changing them lol Or where would i get them?
Ian
#4 mad4classics
mad4classics
  • 200 posts
Posted 10 April 2016 - 01:16 PM
Minispares or Burlen for SU parts:-
AUC1316
AUC1336
C-AEG488 is a good manifold if you want to buy new or it's a search for a second hand one.
(Sorry tapping on a phone or I'd have pasted links)
#5 Ianm11
Ianm11
  • 93 posts
Posted 10 April 2016 - 01:19 PM
AUC1316
AUC1336
How do i go about adjusting the float bowls? Is it a big job?
Appreciate your help
#6 mad4classics
mad4classics
  • 200 posts
Posted 10 April 2016 - 01:42 PM
The float bowl is simply held on by a single bolt that passes right though the carb. If you're at all unsure of the condition of the carbs now is the time to think about refurbishing them.
#7 Ianm11
Ianm11
  • 93 posts
Posted 10 April 2016 - 01:50 PM
They were fully rebuilt when i bought them but obviously maybe from an mg or something. So its just a case of removing the bolt and insert the different grommets?
#8 carbon
carbon
  • 2,590 posts
Posted 10 April 2016 - 06:09 PM
Ian,
How far do the heatshields need to be moved out to clear the exhaust?
On some twin HS2s there is an alloy spacer about 1/4 inch thick between the manifold and the heat shields. And with some HS2 heat shields they are also stepped to give a bit more clearance.
#9 mad4classics
mad4classics
  • 200 posts
Posted 10 April 2016 - 06:20 PM
Not quite, like all simple jobs they grow. Lets see....
You need to remove the self tapping screw that holds the link arm to the jet (care here the whole things under spring tension and sometimes the ferrule through which the screw passes is attached to the link arm but can be a separate brass piece which is easily lost). This will allow you to swing the link arm aside to gain better access to the bolt head.
If you're turning the float bowl by a further 10degrees I would say it's best to remove the jet from the float bowl entirely and replace the sealing glad AUD2194 to be on the safe side even if these are "newly refurbished". You definitely don't want any leaks!!!!
At this point you'll be able to undo the bolt holding the float bowl and replace the grommets. You can the replace the jet and reconnect the link arm (remembering this is under spring tension).
#10 mad4classics
mad4classics
  • 200 posts
Posted 10 April 2016 - 06:30 PM
Ian,
Yes, I've got the 5mm insulating gaskets
http://sucarb.co.uk/...sket-11436.html
#11 Ianm11
Ianm11
  • 93 posts
Posted 10 April 2016 - 06:46 PM
Ive actually just ordered the parts on minispares inc the manifold and  the rh and lh 30 degree grommets. do i need those gaskets? Where do they go?
#12 mad4classics
mad4classics
  • 200 posts
Posted 10 April 2016 - 07:06 PM
Dooooh...
If you haven't got these they go between the carb and the heat shield (I think - it's dark and I'm not going outside to look) and you'll need six hs2 gaskets to fit it all together.
Edited by mad4classics, 10 April 2016 - 07:10 PM.
#13 Ianm11
Ianm11
  • 93 posts
Posted 10 April 2016 - 07:09 PM
Dooooh...
If you haven't got these they go between the carb and the heat shield and you'll need six hs2 gaskets to fit it all together.
haha ok ill order those spacers and gaskets:) thanks again. Is it ok to pm you when they arrive if im having bother fitting them? :lol: :lol:
#14 62S
62S
  • 1,248 posts
  • Local Club: You must be joking!
Posted 10 April 2016 - 09:27 PM
It looks like you can swap the heat shields around so the step in the heat shield should move the heat shield away from the exhaust manifold not towards it.
Your manifold is from an MG1100 so the angle should be OK, it is the position of the carb. bodies that is different (closer together than on a Cooper). Not a problem with your filters.
Edited by 62S, 10 April 2016 - 09:31 PM.
#15 Ianm11
Ianm11
  • 93 posts
Posted 10 April 2016 - 09:43 PM
So all i need to do is swap heat shield around?
