Standard Clutch Diaphram With Updated Plate...
5 replies to this topic
#1 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 11 April 2016 - 03:07 PM
Hey guys,
I've just received my new clutch bits from minispares and some stupid idiot order a blue diaphram instead of an orange, with their performance clutch plate!
It's a fast road engine with around 90bhp that gets some stick. Will this be ok?
I found the previous orange a bit heavy on my dodgy knee so this one would be nice if its going to be ok??
#2 nicklouse
  • 18,998 posts
Posted 11 April 2016 - 03:11 PM
most likely slip.
but you don't spec what plate.
loads of "performance" and Performance parts out there.
#3 screech
screech
  • 3,136 posts
Posted 11 April 2016 - 03:15 PM
Clutch plate:
http://minispares.co...|Back to search
Diaphram:
#4 screech
screech
  • 3,136 posts
Posted 11 April 2016 - 03:41 PM
I've still got the orange diaphram that I could swap the thrust plate over from the new blue one, but not sure if that's likely to be my problem.
#5 nicklouse
  • 18,998 posts
Posted 11 April 2016 - 03:44 PM
you might get away with it  but I have always found that a stronger spring was the better option first.
try it. at least changing the spring does not need the flywheel off.
#6 Craig89
Craig89
  • 600 posts
Posted 11 April 2016 - 07:14 PM
I used the AP rally plate with a blue diaphragm. It was fine for the 2000 miles that i drove the car.
