Upgrading My Alternator. How To Upgrade The Wire?
Posted 14 April 2016 - 07:41 AM
I'd just like to know how you upgrade the wire that goes to the solenoid on the inner wing please. Not sure how you go about putting it in to the plug that goes in the alternator. And am I right thinking it needs to be grade 4? Thanks
Posted 14 April 2016 - 07:43 AM
Grade 4 isn't a term i've heard before, but it's rating needs to be in excess of the alternator output. It also depends on the number of outputs from the alternator. Later pre-engaged setups have 2 outputs and a triggre wire so the load can be split across the two terminals.
I make this exact upgrade, so if you want the cable made with the terminals etc give me a shout.
Posted 14 April 2016 - 02:26 PM
I might be wrong on this, so correct me, if I am. I assume the alternator produces amps according to the demand. So I just swapped 45 A alt for similar shape 70 A one, renewing connections, what were somewhat corroded, and thats it. I havent noticed any ill effects from this modification.
Posted 14 April 2016 - 02:52 PM
This way you can upgrade to 4awg or even 2awg if need be.
How have you come to the conclusion that you need a bigger one?
Posted 14 April 2016 - 03:04 PM
AWG or SWG maybe but not grade 4, as thet is wire wool
Wire sizes are better stated as CSA x strand count, as current travels on the outside of wire and not in the core. the more surface area you have the more current you can carry.
CSA is the cross sectional area (PIxd^2)/4
PI = 3.142.........
d = diameter in mm
d^2 = diameter in mm squared
This will allow you check you have the correct wire size/s
but I would go with 10mm2 total CSA and try to get higher strand count as this allows for more flexibility and reduced fatigue failures, also don't solder it as you will get "wicking" and it will quickly fail
Posted 14 April 2016 - 03:39 PM
Lets assume your wiring was designed to cope with 50A ie 45A + a bit for safety, you fit a 70A alternator and as soon as the demand goes above the 50A the wires will increase in temperature due to internal friction (resistance) then as the temperature increases so does the resistance and very quickly you could end up with a fire, now if all you changed was the alternator and didn't add any extra loads it probably won't make a difference or not enough to worry about, but start adding loads. big amplifier, heated front screen etc etc etc and you can expect a thermal event.
Posted 14 April 2016 - 04:14 PM
Yes, all this is what I dont have:) Not even radio! If I was to add anything extra I was thinking to add separate wiring from the alternator via separate fuse box.
Posted 14 April 2016 - 05:23 PM
Posted 14 April 2016 - 05:56 PM
I should have said that demand on an alternator will reach the 100% mark, at any point the battery needs a top up, so it is still best to the job correctly, fit larger / higher capacity wiring
Posted 14 April 2016 - 06:03 PM
Posted 14 April 2016 - 09:09 PM
WiredbyWilson I might just take you up on that thanks. Would that just replace all the wires in the plug going to the solenoid then? I've got an inertia starter and the 3 spade connectors in a plug going into the altenator.
I think my alternator isn't working as it should as it's only reading 13.5 ish when running and when I turn on lights, heater etc it goes down to 11.8. I've got a few extra electrical things from standard and the biggest battery I could fit in the hole so thought it would be best to upgrade it. And my battery has been flat a couple of times recently.
Posted 15 April 2016 - 12:03 AM
Point taken, thank you. I think I might add another wire from the alt to starter solenoid. From there the original wire back to the battery is beefy enough, isn't it?
Yes the battery cable will take a lot more than your alternator will kick out, however try to get just one wire from the alternator to the starter terminal rather than a bundle,
Posted 15 April 2016 - 07:03 AM
