Mpi Overheating Problems- Best Approach
2 replies to this topic
#1 retrohire
retrohire
    Starting My Mini Up
  • 3 posts
Posted 14 April 2016 - 11:54 AM
Having just spent about £ 800 trying to cure over heating problems on our  98Paul Smith unnecessarily I thought I would suggest ways to approach MPI overheating. Symptoms were expansion tank boiling over with guage halfway on normal and without fan coming on. A pyrometer check showed that temperature in the sensor never got high enough to turn on fan ( 105 degrees ) so we assumed head gasket failure and spent a lot of time and money removing and replacing the head needlessly.
Best approach seems :
1. check electric fan removing temp sensor lead should turn fan on if nec upgrade sensor connection with minispares rover upgrade
2. replace expansion tank cap with minispares one  if this doesnt cure the problem
3. check / change thermostat for correct 88 degree one
4. Change radiator only about £ 70 from minispares if that doesnt work only then check head gasket, head gasket failure is rare on these engines.
We had exactly the same problem on our 1998 Sportspack which boiled over within 5 minutes of starting again with the temp guage only halfway, we changed the expansion tank cap no better and then the radiator and no problems after that , so it seems the radiators can be a problem
#2 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 14 April 2016 - 01:30 PM
Good post! I would always check CTS first, then thermostat, then cap, then radiator.
#3 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 14 April 2016 - 03:03 PM
you should have asked on here, that's pretty much what the advice would have been
